Old 05-04-2021, 07:40 AM   #1
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Deep Cycle or AGM battery thoughts needed!
Yesterday was the day to get the trailer out of storage. Took the batteries off the winter trickle charger, and decided to check tham with a load test before heading out 2 1/2 hours to the storage shed. Batteries showed on the border line weak/ ok, so it is time to replace them. In 2 weeks the batteries will be 7 years old. They are maintained very well, with fluid checks monthly when in the trailer and when on the bench on trickle charge. Trailer has a PD9245 converter. My friends are telling me to replace them with AGM batteries. Last night I was checking out prices on the internet. My local supplier has Deep Cycle, Group 27 batteries on sale for $99.50, and Optima AGM for $319. Canadian Tire sells Deep Cycle for $166 and they have 2 different AGM's for $479, or $299. We use our trailer in the summer about 50-70 nights. Hopefully we can go back to Yuma for 4 months this winter. Do I spend the extra and get the AGM's or continue the Deep Cycle's? Will I gain enough to compensate for the price of the AGM'S. I'm not "cheap", but see no need to waste money if not needed. We camp with shore power 95% of the time, and if we have to boondock I carry 2, 2000 watt gen sets with parallel cable set up. What are some of your thoughts on which way to go? Thank you for your ideas and what you have done in this situation.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 05-04-2021, 08:25 AM   #2
batman's Avatar
1964 22' Safari
modesto , California
Good question.
As some have said here it is hard to beat Costco Golf cart batteries for the value. A true deep cycle battery.
Compare price and Amp hrs.
Costco: 6V Group Size: GC2
Part Number: 9-GC2-UTL
Voltage: 6
Reserve Capacity(RC) @ 25Amps: 105
Reserve Capacity(RC) @ 75Amps: 175
Amp Hours(Ah) @ 20Hr: 210
Amp Hours(Ah) @ 5Hr: 175
Length: 10 5/16"
Width: 7 1/8"
Height: 11"
Weight: 58lbs
Your Price: $98.99
Lifeline: RV Battery Specifications. Also rated as Deep Cycle battery.
Voltage 6v
Length - in 10.28
Width - in 7.06
Height - in 9.92
Weight 66.00 lbs / 30.00 kgs
Lifeline Battery
Part Number: GPL-4CT Cold Cranking Amps: 1095 Rated Cap.
Amp. Hrs: 220
20 Hr Rate Minutes of Discharge
68° 32° 0° 25 Amps 15 Amps 8 Amps
GPL-4CT 1095 925 750 220 492 856 1692
Your Price: $309.50
FYI, I have been told that Optima is no longer the same company and to steer clear. They have down graded there warranty and are no longer made in the USA. Many new failure issues.
Many folks are converting to Lithium batteries now. They are significantly lighter and significantly more expensive. However in the long run may be even more cost effective. IDK.
All this being said. I have four of the Lifeline GPL-4CT batteries in our Safari that have lasted for 10 years. Pretty good value I would say.
Best of luck,
-Dennis
batman is offline   Reply With Quote
Old 05-04-2021, 08:52 AM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The Optima configuration has lower capacity than the standard batteries so that is out for me. I do not think the AGM provides more power. The golf cart batteries might provide more usable power. But if they do not fit and you have to rewire they require some effort. I am also buying batteries this year. Have not decided yet. Looking fondly at the possibility of lithium batteries.
Bill M. is online now   Reply With Quote
Old 05-04-2021, 09:02 AM   #4
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Originally Posted by CBWELL View Post
We camp with shore power 95% of the time:
That says it all. No need for anything fancy and expensive. Stick with same as you already have.
kscherzi is offline   Reply With Quote
Old 05-04-2021, 09:05 AM   #5
2000 25' Excella
Northern , California
From my perspective the answer is pretty straightforward, though I suspect that most of the respondents to your query will disagree with me. Your useage and battery care is similar to mine, i.e., rare dry camping and proper charge maintenance; consequently, high-priced batteries would not be cost effective. If I continue to get a decent number of years out of the Costco/Interstate, etc. hybrid RV batteries, then that's what I'll continue to use. If not, I'll switch to group 27 automotive starting batteries because they have a longer guarantee. I'm also thinking I might just use one battery, rather than two since I only need battery to operate the water pump during brief pit stops. An automotive starting battery will serve that purpose without difficulty. I did use a single battery for one season, and it worked perfectly fine...I just insulated the connectors of the unused battery compartment.
I hope this helps.
Kamiak is offline   Reply With Quote
Old 05-04-2021, 09:45 AM   #6
2019 27' International
Western NC , North Carolina
The only real advantage to going AGM is maintenance. Or lack there of. No need to worry about water levels etc. obviously charging correctly and winter maintenance charging remain the same.
2019 International Serenity 27 FBQ “TC Escape”
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 05-04-2021, 09:47 AM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My previous trailer had a 10+ year old Lifeline AGM that was working great and my current trailer has a pair of 6 volt Lifeline AGM batteries which are doing very well. I find they are very dependable, do not out gas and are maintance free.
Richard
Old 05-04-2021, 09:58 AM   #8
2016 30' Classic
Napa , CA
I agree with this. You already have your battery routine down with the flooded cells, it seems to work for you (7 years life), and you mostly have full hookups.
Dave001 is offline   Reply With Quote
Old 05-04-2021, 04:55 PM   #9
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Well, went to the battery store this afternoon. I had a very good discussion with a very knowledgeable sales and service person. At the end of it all he suggested that the Deep Cycle flooded battery would be my best purchase, based on my maintenance schedule and type of use. I brought 2 new one's home. Thank you all for the insight and thoughts. If the price of the AGM's was closer to the Deep Cycle, I probably would have gone that way. Tomorrow they get installed!
ACI #7394
1976 22' Argosy
Hensley Hitch
Old 05-04-2021, 06:40 PM   #10
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
It sounds like you made a good choice.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 05-05-2021, 07:00 AM   #11
batman's Avatar
1964 22' Safari
Excellent choice!
-Dennis
Old 05-05-2021, 10:21 AM   #12
Bacliff , TX
If you are considering AGM batteries, you should consider switching to lithium batteries.
This is a video worth watching.
This is a good video that ran tests on AGM, flooded lead acid and lithium.
Sources for quality lithium batteries include:
AMPS Lithium
https://lithiummarinebattery.com/shop
Battle Born Batteries
http://www.battlebornbatteries.com/
LiFeBlue Battery
http://www.lifebluebattery.com
ReLion
https://relionbattery.com/products/lithium
SmartBattery
https://www.lithiumion-batteries.com...-rv-deep-cycle
jimdelane is offline   Reply With Quote
Old 05-05-2021, 10:47 AM   #13
Rgentum's Avatar
2016 27' Flying Cloud
Olympia , Washington
I have a 2016 AS that I bought new and soon thereafter I replaced its lead acid batteries with Group 27 AGMs that I bought on eBay for around $175 each with free shipping. They're still working just fine five years later with absolutely no maintenance except a trickle charger.
In 2011 I bought a twin diesel cabin cruiser and replaced all of its batteries (engine starting, house, generator starting, & bow thruster) with AGMs (at approx. $4K), and they are still working just fine, again with absolutely no maintenance except a trickle charger.
Alta & Richard, Olympia, WA --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 05-05-2021, 10:53 AM   #14
2018 26' Flying Cloud
Oriental , North Carolina
Your choice is a good one, basically because you take care of your batteries. Many owners don't, then wonder why their batteries fail. You, on the other hand, are a good caretaker.
Captn.Ken is offline   Reply With Quote
Old 05-05-2021, 11:23 AM   #15
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
New batteries are in the trailer. Before I installed them, I got thinking of the orientation of the positive post. The positive post has always been closest to the compartment door, and with the Group 27 batteries the clearance when removing is very tight. A couple of times the rubber post cover has move when pulling out the batteries to check them and have had an arc. I have always bee
n taught to remove the negative post first, then the positive. Looking at the cable length in the compartment I was able to install the batteries with the negative post closest to the access door. Now when I check the batteries, I can disconnect the negative post and not have to worry about an arc. I guess that you are never too old to learn something! Thanks again for all of the input. Chris
ACI #7394
1976 22' Argosy
Hensley Hitch
Old 05-05-2021, 12:43 PM   #16
1978 31' Sovereign
Green Valley Lake , California
AGMs are preferred by off roaders as they can handle the shocks of rocks and bumps better than sealed lead acid. Unless ur going down bumpy roads at off angles, the cash savings of deep cycle SLA will be just fine in ur coach.
SouthForkAS is offline   Reply With Quote
Old 05-05-2021, 05:04 PM   #17
Half a Rivet Short
Carlisle , Pennsylvania
Hi
There are three basic choices:
1) The cheapest flooded cells on sale at Costco or your favorite outlet.
2) AGM's from a variety of suppliers.
3) Lithiums (also from a range of suppliers).
Looking at immediate cash outlay, number 1 wins hands down. For a "never use battery" use case, this is also the winner.
Looking at long term cost or at performance, number 3 wins by a wide margin.
AGM's used to be the "long term" winner. These days ... not so much.
Old 05-05-2021, 11:35 PM   #18
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Five years ago, I too went with lithiums, solar, and an inverter/charger. Today, I realize that system is by far cheaper and more reliable than either the flooded cell or AGM systems in the long run. Zero worries and complete reliability.
guskmg
Old 05-06-2021, 07:11 AM   #19
MaineStreamer's Avatar
2007 20' Safari
Old Orchard Beach , Maine
AMPS Lithium
LiFeBlue Battery
ReLion
SmartBattery
That was a painfully geeky 37-minute video. I suppose it probably ended with bottom-line recommendations, but I died before the end. RIP to me.
Marty Womer
Old Orchard Beach, Maine
Trailer name: Quarantina
2019-2021 President, Northeast Mountaineers Airstream Club
MaineStreamer is offline   Reply With Quote
Old 05-06-2021, 03:12 PM   #20
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
We have used the Interstate flooded batteries since 2007. Each set lasted 7 years. With a 100watt portable solar panel, we're good, we have low electric demand. We've gone eight days (until we ran out of water). I'm putting 280 watts of solar on the roof as soon as the parts arrive. I also need new batteries and see that Interstate now has "EFB"- Enhanced Flooded Batteries. Wet, but no maintenance, claim they double the life. I'm not expecting (or wanting) 14 years out of a battery, but I'm interest to see how they work.
2019 Ford Expedition Platinum
Can I replace 12V AGM battery with 12V deep cycle battery? iainmcc Batteries, Univolts, Converters & Inverters 10 06-06-2020 08:05 AM
Replacing 12V Deep Cycle with AGM or Lithium M and M Batteries, Univolts, Converters & Inverters 30 06-04-2020 11:33 AM
AGM to Deep Cycle Batteries Bradley G Batteries, Univolts, Converters & Inverters 18 05-04-2019 09:09 AM
Which Deep Cycle Battery? boltos Batteries, Univolts, Converters & Inverters 26 12-07-2004 05:57 PM
deep cycle battery replacement 26Argosy.ca Electrical - Systems, Generators, Batteries & Solar 6 01-02-2003 05:19 AM
