Old 05-22-2024, 02:54 PM   #1
ROMeilia's Avatar
Larue , Texas
Dead batteries and shore power doesn’t work
2021 25’ Globetrotter FBT … ground cable loose and batteries drained. Shore power wouldn’t run lights or recharge batteries. What could problem be and what is fix?
ROMeilia is offline   Reply With Quote
Old 05-22-2024, 03:13 PM   #2
2022 33' Classic
Chesapeake , Virginia
Lithium, or lead acid batteries? If lead acid, they may be toast if drained all the way. If lithium, tighten connections, check converter AC breaker, it may be tripped.
Good luck.
BGClassic is offline   Reply With Quote
Old 05-22-2024, 03:19 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Go to your power distribution panel and flip off, and then on for the main breaker, and then might as well do the other breakers also. Now you know it isn't likely a tripped breaker. Test operation of 120v items like lamps, or fridge, or any outlet. Sometimes the 120v power cord connection or source breaker (maybe in the house) trips and thus fails to deliver the 120v to the trailer.
If all okay, not you can check your converter to ensure it hasn't tripped or blown a fuse. It should be applying maybe 14v dc to the low batteries and then settle down hours later to 13.2 volts.
Troubleshooting is such fun.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Batteries were dead while on shore power Eric9dodge Electrical - Systems, Generators, Batteries & Solar 2 10-27-2023 08:25 AM
AC Unit seems to work on shore power & batteries, but not on generator Rocinante Sprinter and B-van Forum 45 11-18-2022 02:15 PM
Should shore power work when batteries are uninstalled laragc General Repair Forum 2 03-08-2020 10:52 PM
Batteries run dead with shore power hjnj Electrical - Systems, Generators, Batteries & Solar 13 06-12-2018 08:16 PM
house battery seem dead/ shore power dead joe rv guy Sprinter and B-van Forum 29 12-26-2016 12:36 PM
