Old 07-13-2020, 05:43 PM   #1
1977 27' Overlander
Greenville , South Carolina
DC power STOPPED- 77 Overlander
I have several problems with my 77 Overlander:
1.When hooked into shore, no shore and into the tow vehicle , I do not have any 12v working components that work (interior lights)
2. When hooked up to the tow vehicle the outside trailer lights work but no interior lights.
3. The electric 12v ball hitch thingy lifts the trailer
Hereís what I know, only the left side battery charges with the converter (13v). The right side doesnít charger when hooked in either the shore line or tow truck. I replaced the fuse for the right side battery. The system is original.
I replaced the 30amp main breaker but still no 12v power. I donít want to buy a new charger until I fix this problem.
Where is the converter located. The 12v board is located behind the front seat but I canít find the converter. I can here it humming.
Dcyoung is offline   Reply With Quote
Old 07-13-2020, 06:26 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Don't understand what you mean by left side charging and right side not charging.
Do you have 2 batteries? Are they not located together?
What 12 volt things work in the coach? Besides the tongue jack.
Lights, fans, water pump etc.
Old 07-13-2020, 07:17 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
First thing is to check your batteries and see if they are charging, and holding a charge. Have you checked the fluid level in the batteries? Your converter is probably the old Univolt, and if so, replace it now. There are fuses on the univolt on some trailers, some have a seperate board with 12 volt fuses. You have to remember that you have 2 seperate electrical systems in your trailer. 120 volt and 12 volt. All interior lights are 12 volt, as is the furnace fan, ceiling fans, A/C control board and fridge control board. Your 120 volt powers the wall plugs, A/C compressor and fans, fridge when on 120 volt not propane. You have a seperate 120 volt load centre with breakers. Your converter plugs into a wall outlet and is supplied power from 120 volt shore power, converting to 12 volts to the batteries. Your tow vehicle connections powers all the exterior lights, electric brakes and a tiny amount to the batteries. The weakest link in your 12 volt system is the old Univolt, which oveercharges and boils batteries. Hope this helps! Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Fan stopped, now Dometic fridge stopped-what now? BWright2016 General Repair Forum 10 08-27-2017 12:14 PM
Power Awning stopped working Doc Foster Awnings 22 05-23-2016 08:17 AM
New Atwood power jack stopped working SeaLevel Jacks, Stabilizers, Lifting and Leveling 23 01-30-2016 06:18 AM
Dash Air Fan, Power window and Power Seat Stopped working alvinator Land Yacht/Legacy Motorhomes 3 07-13-2014 09:22 AM
Electric Power Hitch Stopped going up. THEPILL Electrical - Systems, Generators, Batteries & Solar 3 12-07-2011 08:23 PM
