09-18-2023, 09:51 AM
2023 25' Flying Cloud
Naples
, FL
Converter stops charging every so often while on shore power
I have a 2023 FC 25 RBT. It is currently hooked to 50 amp power that will run ACs. For the last month or so I will intermittently find batteries as low as 60% while on shore power. I have turned circuit breaker on off. No charge. Taken panel off to get to converter and checked wires. None loose. Or anywhere else I can get to. I’ve tried wiggling wires to see if a break inside wire or defective connection. No change. Then after trying all that and turning main shore power off and on a few times to no avail I turned storage button (button on wall to push when in storage) from on position I leave it in to off then back on m and the last two times I heard a beep, then converter fan on and suddenly charging each battery at 6 amps.
I have two Renogy lithium 100ah batteries with monitors I use to check status and both show great charge after I turn storage button on and off.
Seems like converter needs to be disconnected from power to reboot??? Thoughts as to diagnosis or solutions versus try a new converter which could take weeks to get in for warranty work.
And of course this is an intermittent issue as it can charge for days perfectly then I come out one day and only solar panels charging. I have the 3 solar panel option installed by AS.
Thanks in advance
09-18-2023, 01:48 PM
2022 33' Classic
Chesapeake
, Virginia
Thanks in advance
The WFCO converter in our 22 Classic became intermittent. Awakened at 3 AM in 24F Colorado by the fridge alarm. Lithium batteries were at 37% SOC. I found I could rap on top of the converter and it turn on. I bought a Progressive Dynamics converter and installed it, so far so good. Airstream had me return the failed converter to them, and the receipt. This seems fairly common, several other posts like this one. Good luck.
Bill
09-18-2023, 02:14 PM
Naples
, FL
Thank you. Do you have model number on the converter?
09-18-2023, 03:48 PM
2022 19' Bambi
Northeastern
, Pennsylvania
Sounds like your converter may be set for lead acid batteries. Are you sure it's set up for lithium? If it's one of the WFCO auto-detect units ("-AD" models), many folks have had trouble with them properly detecting lithium batteries. Some have sent them back to WFCO for firmware updates, or gotten frustrated and replaced them. If it's one of the lithium switch units ("-LIS" models), then make sure the switch on the DC fuse panel is set to "LI."
You should be getting more than 6 amps per battery (12 amps total) if your batteries are at 60% SOC. The factory WFCO converter in my 2022 Bambi is a "-LIS" unit, and puts out its rated 55 amps when bulk charging in lithium mode.
09-18-2023, 07:15 PM
2022 33' Classic
Chesapeake
, Virginia
I called bestconverter.com. PD9160ALV is the model. DarthBrader raised a good point, but mine worked correctly for nine months. I hope Airstream knows which converter to use.
09-19-2023, 01:27 PM
Cloudland2
2016 25' Flying Cloud
Trenton
, Georgia
My 2016 FC is stock as far as batteries and upgraded converter. Are leaving the use/store switch on USE? If I’m on shore power and the switch is in store, the converter is disconnected, no charging.
Dave & Carolyn
WBCCI #2584
09-19-2023, 02:42 PM
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake
Look for a bad main power relay. The bang on it is the clue. They fail, the relay hold in winding is not working.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Battery, Controller, and Converter Upgrade - not charging on shore power
mbsprouse |
Electrical - Systems, Generators, Batteries & Solar |
4 |
09-19-2023 02:11 PM |
Batteries Stop Charging on Shore Power every few days. Replugging fixes temporarily?
Hamlit |
Batteries, Univolts, Converters & Inverters |
6 |
12-21-2020 11:27 AM |
No AC Power while on shore power
csregan |
23 |
07-12-2020 09:19 PM |
Go Power! Charge Controller Stops Charging
stanp001 |
Generators & Solar Power |
7 |
04-25-2017 09:58 AM |
Charging Battery While Plugged in to Shore Power
Kevin245 |
2 |
12-29-2007 01:10 PM |
