Old 10-02-2022, 05:26 AM   #1
2022 27' Globetrotter
Bethlehem , Pennsylvania
Converter not going into bulk mode
I have an auto-detect WFCO converter that came stock in my trailer. When I run down the batteries it doesnít kick into bulk mode (14.2V) to increase the charging rate to the lithium batteries. I know that the voltage across the battery will not go up when the converter kicks into bulk mode, but the current should. With just 10% SOC, the current as read from the Smart Shunt is only 10A. After 6 hours of charging the SOC is only 30% and the current is down to 6A. Iíve unplugged from shore power, turned off all the breakers, shut all accessories off, and cycled the DC power off, didnít help. The converter does have a blue light so itís in lithium mode. Any ideas on how to reset the converter?
Merlintiaga is offline   Reply With Quote
Old 02-06-2023, 07:21 PM   #2
2018 16' Sport
Ofallon , Illinois
I have a similar issue with my WFCO 9855 AD converter. I have the blue light but it won't switch to lithium charge mode. Did you ever get it resolved?
CradHltn is offline   Reply With Quote
Old 02-07-2023, 04:37 AM   #3
My trailer has been at Colonial since 12/10 (not a huge deal since itís not camping season for me). At first they said it was my shunt, which of course is wrong b/c a shunt does not affect charging. After a bunch of back and forth, they put a more senior tech on the issue. My converter was not in the batch of serial numbers to get the firmware upgrade, but they went back and forth with WFCO. They finally decided to have the firmware upgraded which is where I stand now. The converter was sent back to WFCO about two weeks ago. Waiting for update from Colonial.
One thing that helped prove my issue during this saga was to have screen shots of state of charge. Clearly my converter was not going into bulk mode (but every once in a while it would. I showed these screenshots to the senior tech who was like, ďyup, this converter is badĒ.
Old 02-07-2023, 06:01 AM   #4
"Cloudsplitter"
This would be my choice TETO
"You don't know where you've been until you leave, enjoy life" RLC
Old 02-07-2023, 07:49 AM   #5
2022 27' International
Poway , California
This is EXACTLY what I did no more wondering if it auto detected or not and now it is charging at 55amps.
My new 2022 27FB WFCO 9855AD would never switch to lithium no matter what I did. I sent it in for the firmware update but even after that it would never switch to lithium mode. I drained the batteries plugged it in and repeated this a few times just gave up.
Since the converter sits behind the electrical panel you can't see if it is in AGM or lithium mode anyway so why be wondering all the time. Just change it out to a fixed lithium converter and be done with it.
markuscis is offline   Reply With Quote
Old 02-07-2023, 08:50 AM   #6
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
This is what I have, not sure itís still in production, itís strictly Lithium. Thatís okay, I am not planning on moving back to Lead(AGM). WCO WF-8950L2-MBA
Silvr_Bullet is offline   Reply With Quote
Tow in sport mode or comfort mode? kevinkatz Tow Vehicles 32 02-07-2022 09:51 AM
VICTRON mutiplus goes into INVERT mode and then disconnects ext AC waninae39 Batteries, Univolts, Converters & Inverters 24 04-18-2020 09:34 AM
Winter mode to keep coach plugged into ac Lford Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 01-17-2019 07:22 AM
My 2017 AI went into limp mode... BocaDad Sprinter and B-van Forum 3 07-10-2017 07:32 PM
Converter remains on bulk charging JK3500 Batteries, Univolts, Converters & Inverters 3 08-08-2009 09:44 AM
