Old 08-13-2020, 09:29 AM   #1
2020 20' Bambi
Dearborn , Michigan
Controller vs converter/charger: 1st in a series
I have a number of questions regarding how my electrical system works. I have read the manual, but still am unclear about a few things.
1st: How does my system know how to charge batteries during the day and with shore power on? Doesn’t it use both my solar charge controller and converter/charger?
Thanks in advance
Curt
harphunt is offline   Reply With Quote
Old 08-13-2020, 09:42 AM   #2
dznf0g's Avatar
Oswego , Illinois
Basically, it depends on the output voltage of your solar controller vs. the output voltage on your converter. One or the other, both or neither may be programmable, but don't mess with it until you become a battery and charging expert.
In my case, the converter output is at a higher voltage than the solar controller. so, with both powered up, the solar controller sees that the "battery" (system) voltage is at a fully charged state and will not produce any output (or very little).
Conversely, if the solar controller output is at a higher voltage, it will do it's thing and the charger isn't doing much or anything as it sees a "charged system".
-Rich-
Old 08-13-2020, 09:43 AM   #3
2020 Classic 33
Box Elder , South Dakota
Most systems would use both until the programming in each says to stop charging. Simple systems have no user controls to adjust these values. Components like Victron, Blue Solar, Magnum allow for customization of the charging profiles.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 08-13-2020, 11:54 AM   #4
2020 20' Bambi
Dearborn , Michigan
So, whichever one is showing more voltage output takes precedent.
Thanks!
Old 08-13-2020, 12:13 PM   #5
dznf0g's Avatar
Oswego , Illinois
Thanks!
For the most part. Sometimes the specific outputs are flipped for each of the charger vs. controller stages. Bulk vs. absorption vs. float. And sometimes one or the other has a timed, rather than voltage determined stage routine.
-Rich-
Old 08-14-2020, 01:19 PM   #6
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Controller vs converter/charger and cooking the batteries
I am not familiar with the 2020 models, but previous models were notorious for cooking the batteries (the converter/charger would overcharge the batteries or not progressively charge them according to the manufacturer's specs which includes taking into consideration battery temperature).
I have my MPPT solar controller charge my batteries (365 days per year) and not the converter/charger. To do this, I put the Use/Store switch in Store position when connected to shore power with cuts off the batteries from the converter (while leaving them connected to the controller). The rest of the 12V circuit is fed from the converter. If I do need the charger (in which case the controller is generally not supplying any or little charge because of little sunshine), I will switch to Use mode, but cut back to Store mode when the batteries are 85% charged, and then let the controller complete the charge properly.
Two things to check, is your converter sophisticated enough to properly take care of your batteries (as most quality MPPT controllers are), and is the Use/Store switch wired as described above (this can be modified by a dealer if necessary).
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 08-14-2020, 02:20 PM   #7
2020 20' Bambi
Dearborn , Michigan
dznf0g... thanks!
Hermes... good to know. I will check to see if I am able to do the same when I get the trailer back from JC.
Thank you all for the information.
Curt
Old 08-14-2020, 06:39 PM   #8
2020 20' Bambi
Dearborn , Michigan
One last question/thought. When people use a 2000watt class generator and an easy start, they generally need to shut the power off to the converter. How would that work with an ac/dc refrigerator? Since I can’t run on lp, wouldn’t that put my refrigerator on dc power?
Thanks!
Solar Controller vs. AC-DC converter/charger Chuck Generators & Solar Power 8 04-19-2021 08:51 PM
Magnetek Series 900 Model 950 50 Amp converter / charger Specs & Features? Driver1 Batteries, Univolts, Converters & Inverters 9 12-26-2020 01:35 PM
SOLD: Progressive Dynamics Inteli Power 9100 Series 60 Amp Converter Charger PD9160A Mx468 Airstream Classifieds 0 07-19-2020 05:18 PM
1st Trip, 1st Day, 1st Mistake BirdDog On The Road... 101 08-26-2016 04:10 PM
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 11:21 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
