Old 01-20-2017, 06:40 AM   #21
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Bill,
On the battery side, with the new Lithiums, the battery cables are entirely new, 4/0 for the paralleling and 2/0 for the in and out. The solar minus had to be isolated, removed from the grounding bus, but the DC loads remain connected to the DC bus as before, including the use of the relay to connect or disconnect loads to the bus. The propane detector is unchanged. I did, however, need to connect the tongue jack to the DC bus. I removed the stock fuse holder with the hard-to-find sb fuse and installed a marine 30 amp circuit breaker in the old battery box. I used the old inverter cable, #4 I think, from the DC bus to the breaker, since that cable was already there. The Orion isolates the BMS and provides DC to the DC bus, including the tongue jack.
Larry
lsbrodsky is offline   Reply With Quote
Old 01-20-2017, 06:47 AM   #22
lsbrodsky's Avatar
BAB,
Am I missing something here? With 6v batteries you would have 2 sets of series/parallel giving you 440amp-hours, not 4x220, wouldn't you?
Larry
Old 01-20-2017, 07:11 AM   #23
2011 25' FB Flying Cloud
Cary , North Carolina
Larry,
Thanks for the info. I see now that you were doing solar as part of your install. I had mistakenly thought you were doing only charger/inverter....I don't have a factory inverter in my 2011 25' FC FB.
troutboy,
Thanks for the clarification. While I am planning on not including solar at this time, I am interested in understanding what would be required for it down the road, so I can ease the future installation work.
Because I am new to my AS, and because I don't have any factory wiring diagrams, figuring out the current physical connections and layout in my AS is proving to be more difficult than figuring out the configuration of the logical circuits. If anyone knows how to obtain "factory" wiring diagrams, I would be very interested.
_
Regards,
Bill
(TV: 2016 Ford Exp 3.5L EcoBoost)
(AS: 2011 25' FC FB)
wmcneil is offline   Reply With Quote
Old 01-20-2017, 07:29 AM   #24
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Yup, sorry for the error....440 is correct. Really happy with the 6V batteries....I think they weigh about 70 lbs each. Lithium will be a nice reduction in "avoirdupois."
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 01-20-2017, 07:34 AM   #25
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
You should be able to obtain the diagrams from the factory. Also, the owners manuals have some basic diagrams as well and they can be found online at the airstream site
Troutboy
Troutboy is offline   Reply With Quote
Old 01-20-2017, 07:40 AM   #26
lsbrodsky's Avatar
I already had factory solar, but that is a non-event in doing the installation I did. Two wires, compared to the other extensive changes. My install was really about the Lithiums, the inverter/charger, and the battery monitor.
Larry
Old 01-20-2017, 08:11 AM   #27
2008 27' International FB
Hillsboro , Texas
Power Distribution Panel
Lew
I am looking to install a 30 amp power distribution panel. Also will install a Magnum inverter.
Thanks for your input.
grwalk is offline   Reply With Quote
Old 01-20-2017, 08:13 AM   #28
Hillsboro , Texas
Lew
Lew
I am asking which Progressive Dynamics Power Panel for 30amp system, you use. Also which Magnum Inverter you recommend?
Old 01-20-2017, 08:18 AM   #29
I have extracted what I could from the owners manual, and based on that and some poking around my AS, created a logical wiring diagram which I will attempt to attach to this post....I'll try contacting the factory, and see if I can get a wiring diagram from them.
File Type: pdf my_2011_airstream_flying_cloud_25FB_wiring_diagram.pdf (200.4 KB, 55 views)
_
Regards,
Bill
Old 01-20-2017, 09:17 AM   #30
lsbrodsky's Avatar
Bill,
I do not know how those 30 amp reverse polarity fuses are actually wired. You won't find them on an AS schematic, they are a part of the converter and my WFCo manual did not have a schematic.
Larry
Old 01-20-2017, 09:46 AM   #31
Troutboy's Avatar
Parker , Colorado
Grwalk,
Here are a few links to the panels Lewster mentioned. I bought mine from here. On the 30/30 panel, make sure you select model PD55B003
http://www.bestconverter.com/PD6000-...l#.WII9XstHahA
http://www.bestconverter.com/PD55B00...l#.WII-BstHahA
Troutboy
Old 01-20-2017, 11:20 AM   #32
Originally Posted by lsbrodsky View Post
Bill,
Larry
Larry,
When I was looking at my existing DC distribution panel, I though those fuses were part of that panel. I'll have to have a close look next time I am digging around.....I contacted Airstream, and after a little email back and forth explaining what I was looking for, they have emailed me back some diagrams already(and at no charge, talk about good customer service!). There is a lot of mechanical detail on them, so I'm hoping they are a nice supplement to poking around in the trailer. (particularly when the wires "disappear" from sight.)
_
Regards,
Bill
Old 01-20-2017, 12:20 PM   #33
lsbrodsky's Avatar
I requested about 20 drawings as I was planning my project. Most were layout drawings that were useless. About 3 schematics had value. The fuse panel is a part of the converter, not an Airstream product so you will not see a detail for that. I used a meter and my eyeballs to trace out the wires to and from the the converter and the DC fuse board.
Larry
Old 12-02-2017, 10:45 PM   #34
2016 30' International
redondo beach , California
Thanks for that drawing.
This is what is lacking on these types of discussions.
RC
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Video: Installing a Magnum Hybrid Inverter in our FC 30 explore more Batteries, Univolts, Converters & Inverters 2 06-29-2016 09:58 AM
Victron Multiplus Hybrid/Boosting Inverter/Charger Install CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 7 03-15-2016 11:03 PM
'61/'99 Hybrid 05ModPod 1997 -2001 Excella 9 07-12-2008 01:38 PM
GM hybrid pickup Silvertwinkie Our Community 9 07-25-2004 02:39 PM
Problem with Hybrid display mode... malconium Forum Admin, News and Member Account Info 1 07-21-2004 05:58 PM
