Old 02-11-2024, 07:27 PM   #1
2022 16' Bambi
Central City , Iowa
Charging LiFePO4 battery from TV
I assume I need to disconnect the 12V wire from my tow vehicle so it doesn't drain the recently installed LiFePO4 battery in my Bambi? Either that or install a 12V to 14.6V converter of some sort.
Suggestions?
Thanks!
rhhol is offline   Reply With Quote
Old 02-11-2024, 08:21 PM   #2
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
A: you can leave the wire in the 7-pin, just unplug when you’re not on the road (just be sure to plug it back in before getting back on the road).
B : yes, if you want to ‘really’ charge while going down the road, something like a Victron DC-DC charger would work (the 12v 50 amp one is just coming out now).
-Leslie
WBCCI #1051
LNBright is offline   Reply With Quote
Old 02-13-2024, 06:43 AM   #3
2022 16' Bambi
Central City , Iowa
Thanks for the info!
Replacing lead acid w Battle Born LiFePO4 Deep Cycle Battery mortizaspen Batteries, Univolts, Converters & Inverters 23 04-16-2022 09:41 AM
Charged Voltage setting for Victron BMV-712 battery monitor with LiFePO4's? qwertyd10n Batteries, Univolts, Converters & Inverters 18 04-25-2021 11:26 PM
Do you disconnect solar or LiFePo4 battery when not using your trailer hovr Generators & Solar Power 4 01-01-2021 03:00 PM
Word of warning for LiFePO4 battery conversions (Battle Born) SilverHouseDreams Batteries, Univolts, Converters & Inverters 153 08-21-2020 05:13 PM
LiFePo4 battery + inverter install & solar prep 03bart 2016 - Current International 11 08-19-2020 06:23 AM
