Old 07-24-2017, 11:55 AM   #1
StephSH's Avatar
2020 23' Flying Cloud
1977 Argosy 28
Frankfort , Ohio
Boondocker conversion
Hello,
We purchased a Boondocker Converter and an F9 fuse box from BestConverter and thought that would be everything we needed to connect and update the battery/converter/fuse panel, but there appears to be a small stand alone fuse relay of some sort (50amp?) that the positive battery cable runs to, and then that runs to the converter.
Currently, there is a black wire connected to both of those connections, but our wiring is a mess, so I wouldnt say that's the way it came from the factory.
Would someone with a '77 Argosy 28 center bath mind sharing a photo of your update converter/electrical set up so we can see what it SHOULD look like?
StephClick image for larger version
StephSH is offline   Reply With Quote
Old 07-24-2017, 03:55 PM   #2
1967 17' Caravel
Cannot tell from your photo, but 120v power goes TO the converter and 12V power goes FROM the converter to the 12V fuse panel and battery (with battery disconnect in between). The 50amp breaker/fuse is probably in the 12v line. Generally, black wires are positive and white are negative/ground. Individual 12v circuits (load) go FROM the fuse panel.
David F is offline   Reply With Quote
Old 07-24-2017, 05:17 PM   #3
StephSH's Avatar
1977 Argosy 28
Frankfort , Ohio
Sounds like the battery disconnect is the part we didnt realize was in play...
Old 07-25-2017, 06:51 AM   #4
1967 17' Caravel
Actually, I cannot tell if you have a disconnect or not. What I was trying to say is you should add one if there is not one already. Attached is a wiring diagram I roughly sketched out just to ensure I wired everything the way I wanted it. I am sure there are different approaches. Hope it helps
Old 07-25-2017, 06:17 PM   #5
StephSH's Avatar
1977 Argosy 28
Frankfort , Ohio
Thanks, I'll take this down and compare it to what we've got and see if it can help us figure things out :-)
Boondocker Solar Package flyrodder Generators & Solar Power 9 12-21-2004 02:54 PM
Ultimate Bambi Boondocker? Pick Our Community 5 11-10-2003 12:47 PM
