Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 09-21-2021, 09:19 PM   #1
Scout
yellowcake's Avatar
2019 28' Flying Cloud
Livingston , Happy Camper, USA
Battle Born Lithium do NOT drop in to battery box
I purchased 2 Battle Born 100 amp Lithium 12V batteries to drop in to my 2019 28’ Flying Cloud battery box. While the dimensions indicate they will fit, there is a lip on two sides of the box that prevents both batteries from sliding in. No amount of tilting or rearranging would get BOTH of them inside.
Has anyone else run in to this problem? BB indicated it would be a no brainer - AND that it would be okay to store them outside as I do not intend to spend any length of time in cold weather.
I am on a tight budget and trying to do this myself. Moving the batteries inside would require wiring far beyond my basic electric 101 capabilities.
Wondering if I can clip the corners where the lip meets the smooth sides and bend the metal back to slide them in and then fold them back down afterwards. I’m afraid this may compromise the structure of the box - or maybe its a way to add a measure of security to lock the box for safekeeping.
Any thoughts?
yellowcake is offline   Reply With Quote
Old 09-21-2021, 09:27 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Remove LP tanks and cover.
Take old batteries out.
Remove battery compartment lid by drilling out rivets. Then remove central rod that holds down batteries (unscrew it)
Cut one side of the lip off using dremel or tool you can rent from Home Depot.
Spray paint a bit so it doesn’t rust.
Drop the first battery in, slide it over. Drop second battery in.
Reattach lid with short metal screws or rivets.
Done.
Many have done this to fit larger batteries in.
wulfraat is offline   Reply With Quote
Old 09-21-2021, 09:36 PM   #3
Scout
yellowcake's Avatar
Thank you!! I especially appreciate the step by step instructions.
I have never drilled out rivets but I’m sure I can see how to do this on YouTube (I have only replaced ones that fell out).
I used to have a dremel, so I’m familiar with this tool and go rent one to cut the lip on one side.
I looked at unscrewing the center rod, but didn’t see an easy way. It appears “fixed” to the bottom of the box from the underside. I’ll check this again. So I’m assuming this center rod is not required and I don’t have to replace it? Please confirm one way or the other.
How do I reattach the lid, once the rivets are drilled out? Is this similar to installing rivets in the walls of the airstream? Will I need a different tool?
Old 09-21-2021, 09:39 PM   #4
wulfraat's Avatar
There should be a bolt welded to the bottom of the battery tray - this is what the rod screws into. You can re-install it after you get the batteries in.
Alternatively, don’t bother - I removed mine and never put it back.
Re attaching the lid - you can rivet it back in. (You would need a small rivet device and a few rivets… they are like $50 bucks or something… handy if you have an airstream [emoji4] )
Alternatively just buy some short metal screws while you are at Home Depot and screw it back down using the rivet holes.
Old 09-21-2021, 10:00 PM   #5
Scout
yellowcake's Avatar
Perfect! I just watched a video on how to remove and reinstall pop rivets. Easy, Peasy.
Speaking of battery tray - - my tray simply lifted it out - there was a hole for the central rod that it threaded through. It was molded on the bottom to fit the lead acid batteries. Do I need to find a new one for the lithium batteries? Or just sit them on the bottom of the box without a tray?
Also If the rod is welded to the bottom how do I remove it?
Old 09-21-2021, 10:03 PM   #6
Scout
yellowcake's Avatar
Oh wait - you said the center rod “unscrews” from the bottom. I didn’t even try that.
Old 09-22-2021, 09:29 AM   #7
​2020 Atlas​
Cleveland , Georgia
Don't rent a Dremel. You can buy one much cheaper. Also, be sure to wear goggles when doing surgery on the battery box.
Krikati is offline   Reply With Quote
Old 09-22-2021, 05:27 PM   #8
2016 28' Flying Cloud
Defiance , Missouri
The GC2 size 100 ah battleborn batteries fit perfectly in my 2016 28RB battery box with no modifications.
Which batteries are you installing?
62olander is offline   Reply With Quote
Old 09-22-2021, 05:34 PM   #9
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Yes, this. I just installed 2 GC2 BB batteries in my 2016 Int. and they fit just fine, and I had room for a shunt and breaker. This is the one that AS is now putting in as a factory option.
thewarden is offline   Reply With Quote
Old 09-22-2021, 05:42 PM   #10
thewarden's Avatar
Here is what my install looked like. I only had to make a small mod to the plastic tray on the bottom and get a longer center holdown rod as the one with the original batteries was too short. It just screws into the bottom of the battery box.
Old 09-22-2021, 07:35 PM   #11
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
That’s a really nice, clean installation!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 09-22-2021, 07:42 PM   #12
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
lion batteries are best kept inside as they do not vent gases
it also keeps them under better thermal control
waninae39 is offline   Reply With Quote
Old 09-22-2021, 10:57 PM   #13
thewarden's Avatar
That is why I got the heated ones. No need to store inside for temp control.
Old 09-23-2021, 12:34 AM   #14
Scout
yellowcake's Avatar
I wish BB had offered this battery. I wasn’t aware and they sent me the regular BB10012. I will call to see if I can exchange them.
Old 09-23-2021, 12:36 AM   #15
Scout
yellowcake's Avatar
So just to confirm - you didn’t have to remove the lip on the edge of the battery box?
Old 09-23-2021, 05:47 AM   #16
Defiance , Missouri
Confirmed...The GC2s will fit with no modifications. Here is the link on their website:
https://battlebornbatteries.com/prod...kit-1-battery/
Old 09-23-2021, 07:55 AM   #17
thewarden's Avatar
I can also confirm. I am surprised that Battleborn did not recommend the GC2 as that is what they told me I needed when I ordered.
And, again, the GC2 is the battery that Airstream is putting in the stock battery box at the factory as an option.
Old 09-23-2021, 10:35 AM   #18
ts8501's Avatar
2022 25' International
Savage , Minnesota
Does anyone know if the GC2 BB’s also fit in a 2022 battery box without mods?
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 09-23-2021, 11:38 AM   #19
thewarden's Avatar
They should fit all battery boxes from 2016 to present.
Old 09-23-2021, 06:29 PM   #20
nryn's Avatar
Driftless Area , Wisconsin
I just installed a pair of heated BB GC2s into my 2019 Globetrotter 27FBT’s battery box. No modifications to the box or the batteries were necessary. I did remove the plastic tray—the metal plate on the threaded rod holds them in place just fine.
Airstream adventures and enhancements thread: Traveling with Tatay
Personal blog (photography, travel, woodworking, flyfishing, food): nryn.com
nryn is offline   Reply With Quote
Replacing lead acid w Battle Born LiFePO4 Deep Cycle Battery mortizaspen Batteries, Univolts, Converters & Inverters 23 04-16-2022 08:41 AM
Battle Born Lithium second best? Boxster1971 Sprinter and B-van Forum 43 12-17-2021 09:35 PM
Battle born/DragonFly 255 AH LiON battery waninae39 Batteries, Univolts, Converters & Inverters 1 01-25-2021 06:27 AM
Word of warning for LiFePO4 battery conversions (Battle Born) SilverHouseDreams Batteries, Univolts, Converters & Inverters 153 08-21-2020 04:13 PM
Battle Born GC2 in stock AS battery box? zonastream Batteries, Univolts, Converters & Inverters 3 02-18-2020 09:13 AM
