Battery terminal buss fuses
Hi,
21 Classic.
Does anybody know what the purpose of the 50A and 100A buss fuses on the battery terminal is? My 50A is bad. The wire that connects to that fuse is the main power 6 gage that comes from the distribution point that has the converter and solar. The 100A is on the inverter circuit.
Seems like if the converter rated DC current is 50A, along with additional input from the solar panels that the fuse would be bigger than 50A? I ordered a replacement and it was rather expensive. Hopefully will not blow another one.
The batteries are already bad now. If I upgrade to lithium, do I keep the same size fuse?
Any input is appreciated.
Arthur
