Old 03-24-2025, 07:19 PM   #1
2018 30' Classic
Dauphin , Manitoba
Battery Swap
Hi to all the experts! The house batteries and the SunExplorer II solar controller and display have failed in my 2018 classic. Replacing the controller and the display is not an issue as I have a supplier in Canada, BUT i am wondering about changing out the batteries. Airstream recommends switching to the Battleborn 100ah 12V GC2 LiFePO4 deep cycle batteries. 1. can I do this without any other equipment changes. 2. Can I continue to store these batteries in the original battery box in the trailer tongue. 3. If i need to upgrade other components, what are they. Thanks for all the help in advance.
BRN25611 is offline   Reply With Quote
Old 03-28-2025, 08:57 AM   #2
2022 27' Globetrotter
Haslet , Texas
My Switch
I switched out my factory installed AGMs with two 100ah lithiums a couple of years ago and have been very pleased. Today I would consider the 300ah battery several folks have mentioned here if it would fit in the battery box. Here's a link to my post with pictures of my install - https://www.airforums.com/forums/f44...um-241239.html. Since then, I've added a 20 Amp Renogy DC to DC charger to recharge the lithiums while driving, because the 7-pin won't carry enough current to charge the lithiums from the TV alternator.
swat2 is offline   Reply With Quote
Old 03-28-2025, 09:29 AM   #3
2019 22' Sport
High River , Alberta
You need to confirm that your existing converter (where the fuses are) is "switchable" to lithium batteries. LiFePO4 batteries have different charging requirements.
With a 2018, you may need to upgrade. I know I would need to with our 2019 22FB. This is not necessarily a major cost relative to the cost of quality batteries.
The batteries could go in the battery box. However, lithiums don't take a charge below 0 Celsius, and performance degrades in the cold. Therefore, many people relocate them in inside the trailer.
On the other hand, there are options with built-in heaters (self-heating) that are effective to about -20 Celsius.
You've got some research to do to determine what makes sense in your situation.
AlbertF is offline   Reply With Quote
Old 03-28-2025, 09:39 AM   #4
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
if in Canada, get the batteries from a CDN supplier. I bough mine from CANAMRV in London ONt
https://www.canamrv.ca
we got these batteries a a few years ago from a cdn source and they work very well
https://discoverbattery.com/products...s/lithium-blue
importing LION batteries is VERY expensive as there is a large shipping and import fee
LION are considered dangerous when shipping , so they charge an extra fee for secure handling
we placed out 4 lion batteries inside. that helps to reduce tongue weight
in the winter, we use a 100W plant heating pad and that keeps then just above 0 C
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
PeteC17
Battery Swap MRA Batteries, Univolts, Converters & Inverters 2 07-19-2023 11:51 AM
Group 27 Battery Swap Ted S. Electrical - Systems, Generators, Batteries & Solar 18 08-19-2020 10:30 AM
Battery Swap from 12v Deep Cycle to 2x L16 for more amp hours Vycan Classic Motorhomes 24 05-07-2016 11:05 PM
Website updated-Water heater swap Safari Tim Water Heaters, Filters & Pumps 1 07-06-2003 01:47 PM
