Another question for you AS electrical guru's.
The manual for my AS says that plugging the trailer into 120v power with the master switch off will blow radio fuses and may damage other 12volt components.
I'm trying to figure out why. Do I need to worry about that little blurb since we no longer have the original univolt system and have a converter installed? It also doesn't seem the converter is installed correctly as the 12v+ conductor goes to the 12vdc distribution panel instead of the battery side of the kill switch.
Thanks and I appreciate any thoughts!
