Old 01-19-2022, 06:38 AM   #1
Point Pleasant , New Jersey
Question Battery Disconnect Switch Fails after Running the Generator
Hi, I have a 2007 Airstream Interstate. I am having a problem with the battery disconnect switch after running the generator. With my house battery charged, I was running my generator. When I turn the generator off, everything goes dark and the battery disconnect switch stops working. When I plug into shore power, the switch works fine, as do all of my appliances and lights. But when I disconnect from shore power, the battery disconnect switch stops working and I cannot turn anything else on. Any suggestions for what’s going wrong and what I need to fix. Thanks!
MessyDeal is offline   Reply With Quote
Old 01-19-2022, 09:01 AM   #2
OrangeCrush's Avatar
2017 25' Flying Cloud
Longmont , Colorado
Check the fuses on your battery disconnect relay.
OrangeCrush is offline   Reply With Quote
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 10 06-26-2020 02:35 PM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 32 08-26-2019 01:23 PM
OK to connect a battery charger when the internal one fails? DJW Batteries, Univolts, Converters & Inverters 3 01-06-2014 11:56 PM
Battery Disconnect Switch Question MaryD Batteries, Univolts, Converters & Inverters 4 07-13-2013 08:19 AM
Battery Disconnect Switch nsbcpa Batteries, Univolts, Converters & Inverters 5 08-10-2012 05:11 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
