2020 30' Classic. Batteries have two positive and two negative major wires coming off of them. My question is if I put a battery disconnect on the right front negative post do I need one on the left battery negative post also? the photo got flipped from the way I took it
2012 25' FB International
Trent Woods
, North Carolina
Well, it isn't going to be disconnected if you only use one lead. On my original wiring one black and red pair went to the inverter, which you also want disconnected if you go to the trouble of a battery disconnect.
Larry
Or...remove all + wires from lower right and install it there.
If that fused red wire is for the jack, moving it is optional.
That is how I wired ours, (but it was inside).
