Originally Posted by Atomic_13
It’s likely you’ve already considered this but if you opt to install a disconnect switch for the batteries be certain the wire that supplies power to the trailer breakaway switch on the A frame remains “hot” even with the switch set to off. Otherwise you or the next owner of the trailer will need to remember to turn the battery switch on before towing. While unlikely, if the trailer would become unattached from the tow vehicle, no power would be applied to the trailer brakes from the house battery unless this wire is “hot”.
This was a consideration when I devised my switch using the negative cables. The breakaway switch uses the negative buss bar, and so would not have power. However, neither would the jack, so it's a easy reminder to flip the switch to "1", before connecting.
In general, I leave the switch on until it goes back to storage.
(I have never used the inverter yet!)
