I wanted the switch on the curb side, so it was out of the majority of splash from traffic, and to make access easier from the door. This required me to move the Zamp connector to the street side, and I attached it with stainless machine screws. All screws have the round heads inside the battery box and the nuts outside so nothing can chafe on the batteries themselves.
Then I used the negative house cables, since they are longer than the positive red. (the batteries are oriented with the neg forward, so the cables are longer) This allowed the existing cables to reach the switch without any splicing.
For the switch I used 90 degree crimp connectors so the cables would exit straight out of the box.
I made new jumpers using 2 AWG wire and a 16 ton Hydraulic crimper from Amazon. It did an amazing job!
I tried to make the cables just long enough to make routing around the filler caps possible
When reconnecting, I kept all the positive leads on one battery and the negative "master" from the switch on the other battery.
The only time I varied that was my harness for the NoCo Genius charger that I did the reverse with. That helped keep the pile of reds to a minimum.
With the charger, the Zamp wiring, and the Jack leads, it does get busy in there.
I'm now using the Zamp connector to power my TST repeater mounted on the lid of the propane cover.
In mounting the switch box, I used some sealant between the battery box and the switch, and I have a rubber grommet sandwiching both together, so I don't think any water can get in. I also put a bit on sealant around the switch and box.
By using the negative leads, with the switch off, the tongue jack doesn't work, so it reminds me to turn the power on to travel.
I made the converter position 1 while the inverter is position 2, so I can leave either or both off or on.
I spent a long time planning, and as Sinatra sang, "I did it my way".
