Old 09-16-2019, 12:39 PM   #1
2018 30' Classic
Traverse City , Michigan
Battery Discharging
We have a 2018 Classic. We woke up this morning to a battery that’s discharging. Our Dealership replaced the Firefly and now it won’t connect to the Alde. Firefly and Airstream can’t agree on what’s wrong.
We had a one week trip,planned and are on it now We’re trying to function without heat and hot water BUT woke up to our battery discharging. Haven’t a clue why. Any suggestions? We keep plugging it into the truck to charge it but the charge won’t hold.
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30’ Classic
SMKovalchik is offline   Reply With Quote
Old 09-16-2019, 01:47 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I think you need to go forthwith to buy a battery charger and hook it up to the batteries. To keep them from going down to far to recover. And so that the heat and lights will function. You just do not get much, if any, charge from hooking it to the truck. I can not help with the Firefly/alde. It sounds like your power converter is not turned on or is not functional. Check the 110 supply to the PC. Check the breaker and for a switch.
Old 09-16-2019, 01:51 PM   #3
Sag Harbor , New York
Contact the dealer ASAP and get them to sort this out IMO. At a minimum you need to be plugged into shore power to get your batteries fully charged.
Plugging into the truck for a couple of hours is woefully inadequate.
After a couple of days on shore power, unplug, wait an hour and report your battery voltage. If you have let the batteries get below 12.2 volts you may have damaged them. Flooded cell batteries or AGM? Water levels OK? Lots of variables!
Good luck,
Peter
PS — Good general primer for RV battery use:
http://www.batteriesnorthwest.com/batteryschool.cfm
Old 09-16-2019, 02:10 PM   #4
ZOZ
ZOZ's Avatar
2018 23' Flying Cloud
Peru , Illinois
Battery 101
Step 1. Separate both batteries from the trailer and each other.
Step 2. Load test each battery. An auto parts store will do this free for you.
Step 3. A healthy battery should maintain a range between 9.5-10.5 volts for 30 seconds under load. Anything less in the reading replace it.
Step 4. Put a Deltran Battery Tender (12v, 5A) on your (new) batteries.
zoz
Cindy & Randy
2018 AS Flying Cloud 23FB
2018 GMC Sierra Denali 4x4 6.2L
ZOZ is offline   Reply With Quote
Gel Batteries are Discharging too Quickly. iamwalmas Electrical - Systems, Generators, Batteries & Solar 28 11-07-2018 05:26 PM
Battery Discharging Overnight Jbart Batteries, Univolts, Converters & Inverters 2 10-05-2013 06:09 PM
Discharging batteries jamesiboles Batteries, Univolts, Converters & Inverters 3 04-24-2009 02:49 PM
Batteries Discharging to Quickly Paul Dobbin Land Yacht/Legacy Motorhomes 23 08-20-2008 05:27 PM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
