10-17-2004, 12:31 PM
Battery Charging with Univolt?
I need to have my '69 Ambassador plugged in full time. Has anyone figured out how to safely charge the battery while leaving the Univolt constantly plugged in? It seems like lots of batteries are overcharging and thus prematurely failing. Also lots of corrosion from boiling battery. Someone has to have figured out an external "smart charger" that you can hook between the Univolt and the battery. Does anyone have a link or a product that is available to make this work? Thanks!!
If there are other problems with leaving things plugged in full time that I am not aware off please chime in.
1969 29' Ambassador International
1994 K20 Suburban w/7.4l
1966 K25 Fullsize Truck w/5.7l
10-17-2004, 01:56 PM
1969 31' Sovereign
Broken Arrow
, Oklahoma
common problem
This is a common problem with the Univolt. I use a battery disconect and from time to time allow the battery to charge as needed , others use a timer between the battery and Univolt do a search and you will find several solutions up to replacing the Univolt.
The disconnect I used is pictured, purchased at a marine store.
Garry
12-03-2004, 08:06 AM
If your concerned about corrsion from batteries get a Optima.......they are sealed at the posts.
Unlike all the other batteries out there.
Man......I sound like I work for them but i don't.
I just love their batteries.
Mike
12-03-2004, 08:22 AM
Blue Top Optima
I too have Optima blue tops and a red top in my Suburban. I love these batteries but have found out a few things of interest. These will die while being constantly charged by the old univolt even faster than the "wet" batteries. Very sensitive to charge rate! If you overcharge an Optima they will vent out their sealed vents and are usually ruined at that point. Change out your electronics and make sure to get a "gel cell" charge wizard. I went through all this a while ago and am happy with the results.
12-03-2004, 08:57 AM
2001 34' Limited
The State of
, Ohio
For a given standard battery size, i.e. Length X Width X Height, the spiral-wrap, "six-pack" design of the Optima doesn't contant nearly as much battery (i.e. lead), and as a result, has considerably less capacity than a conventional AGM. You can see that in the weight. A yellow-top Group 31 Optima only has about the same capacity as a smaller Lifeline Group 24. Optima also does not offer a Group 27 size, and their Group 34 is just a shorter, and less capable Group 24 sized battery.
Code:
Lifeline AGM GPL-31T 105AH 195 min RC (81.3AH) 69 lbs
Optima AGM D31 75AH 155 min RC (64.6AH) 60 lbs
Lifeline AGM GPL-24T 80AH 149 min RC (62.1AH) 56 lbs
Optima AGM D34 55AH 120 min RC (50.0AH) 44 lbs
Lifeline AGM GPL-27T 100AH 186 min RC (77.5AH) 65 lbs
AH rating is at the 20-hour discharge rate (AH/20)
RC is Reserve capacity in minutes at a 25 amp rate.
Don't confuse AGMs with gel cells, which need a lower than traditional bulk charge voltage to prevent thermal runaway. An AGM, Optima, Lifeline, or other brand, should work with any good 3-stage charger designed for flooded cells, and that includes the Charge Wizard. Using a gel-cell Charge Wizard just results in slower charging.
I agree with Bryan. Whether you go AGM or not, pitch the Univolt and get an Intelipower with Charge Wizard.
Maurice
12-03-2004, 09:39 PM
Silver Hilton
1959 24' Tradewind
Astoria
, Oregon
I'm at the point of replacing my deep cycle batteries, and am sold on the advantages of AGM's. I have the original '92 "Univolt" (which I think is actually Magnatek) convertor in my trailer. Should I pitch it and go for the Intellipower?
I did this in my '72 Land Yacht, and was very happy with the change (and the silence!). On the other hand, saving $250 toward purchase of the two new AGM batteries has attraction, if the '92 Univolt is a sufficient performer to justify it's staying aboard.
Thanks for your input!
Mark
12-04-2004, 02:22 AM
2017 28' International
Western
, Oregon
Factory Battery
My 2004 22' CCD has only one battery....a factory installed battery! I've heard on these forums they are whimpy Since I purchased a Honda 3000 EU generator, I didn't want to invest in a new battery immediately. I'm less concerned, now that I can recharge while boondocking (and hookup when available). I plan on traveling to some extent all year (boondocking less during the winter months). My concern is during the longer periods between trips (<30 days), do I need to keep the battery charged? Since my AS is in for service and warranty work now, I asked a dealer service tech if I would need a trickle charger. He said I could plug into shore power indefinitely and not hurt the battery....he replied that it was no problem, since the newer AS's use the automatic built in charge of the converter system for charging. The charging circuit automatically controls the current, reducing it as the battery increases in charge. Is this true?? If so, I will simply check the battery fluid levels monthly and keep it plugged into shore power indefinitely!
Another question...do I leave the battery switch in " use position" or "store position"
JIm
Jim & Cheryl
2017 28' Signature CCD
2017 GMC Denali HD Crew Cab 4x4
Blue Ox Sway Pro Hitch
WBCCI #3538
12-04-2004, 04:57 AM
2004 22' International CCD
Spotsylvania
, Virginia
Hi Jim,
You surely have a model 7355 switch mode charger in your 22' CCD, as I do in mine. I leave mine plugged in to shore power all the time, occasionally topping off the water level. http://www.parallaxpower.com/
As long as you're plugged in, your battery switch will stay in the "Use position".
12-04-2004, 07:58 AM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
Mark
mark i can say this about the magnatek converter, they are rugged units.
mine was running into a battery with a shorted cell for about 2 months with no ill effect!
john
you call them ferrets, i call them weasels.
12-04-2004, 12:37 PM
1975 29' Ambassador
Reno
, Nevada
Some items to note.
1) Lifeline says their AGM's charging values are the same as wet cell batteries. If you check the specs you will see this is so as the recommended ranges, while slightly different have significant overlap. Having different charging characteristics for AGM and wet cell is a nicety and not a necessity.
2) Equalization charging is not reccommended for AGM batteries. This makes me think the normal charge wizard should not be used on AGM's as it implements an equalization charging strategy (if I understand correctly). This 'non equilize' spec has implications for other battery maintainters as well.
3) The Optima batteries have very low internal resistance (Peukert coef 1.06 vs 1.2 for most other AGM and wet cell) This means that lower current draws will yield much better usable energy from an Optima that it will for most other batteries of equivalent weight. (i.e. it competes well with other deep cycles for normal RV use)
4) Gel Cells are a completely different animal and should not be confused with AGM or wet cell lead acid batteries.
12-04-2004, 12:45 PM
Originally Posted by Leipper
Some items to note.
Did you mean much better usable energy at higher current draws?
The Peukert coefficients for the Lifeline and Optimas (both AGMs) are very close.
12-04-2004, 02:18 PM
1975 29' Ambassador
Reno
, Nevada
"Did you mean much better usable energy at higher current draws? "
no.
you get more energy out of a battery when you draw less current.
Look at the spec sheet for a battery that shows you the amp hour rating at differing rates. You will find that the longer rating (which means less current) has a higher amp hour rating than the higher current rating.
This is key to why putting batteries in parallel is as good as or better than serial for equivalent size, type, and weight in small battery banks.
see, for instance, http://www.absolutebattery.com/deepcycle.htm
A 225 ah (20 hour or 1200 minute rate, which is the one you usually see and hear as a measure of battery capacity) golf cart battery provides 75 amps for 115 minutes (142.5 AH) or 447 minutes at 25 amps (186.25 AH). Reducing the load by two thirds (75 to 25 amps) increases usable energy by 37% and reducing draw to last ten times the 75 amp rate brings the usable capacity up to 50% more or better.
75 amps for 115 minutes = 142.5 amp hours energy available
25 amps for 447 minutes = 186.26 ah
~11 amps for 1200 minutes = 225 ah
You can also see the calculation for a 2:1 current reduction at
http://sierranevadaairstreams.org/ow...ry-config.html
One way to visualize this is to realize that any battery has an internal resistance. This is why it gets hot if discharging (or charging) at high currents. The power loss (rate of energy use) for battery heating is related to the square of the current times the internal resistance of the battery. So reducing current reduces power by the square of the current change. This is probably why the Peukert law is an exponential.
do check my calcs! I try but sometimes I see numbers backwards or do other stupid things so I need a good proofreader ;-)
If you need help (or to add to an existing confusion) about power, energy, voltage, current, etc. see
http://sierranevadaairstreams.org/ow...ng/energy.html
and
http://sierranevadaairstreams.org/ow...ectricity.html
"The Peukert coefficients for the Lifeline and Optimas (both AGMs) are very close."
1.06 versus 1.2 makes a big difference when it is an exponent!
12-04-2004, 02:37 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
boy, you guys are really getting into this subject!
with all those numbers my heads starting to spin, i hope i don't have to peukert!
john
12-04-2004, 02:47 PM
2001 34' Limited
The State of
, Ohio
The "equalization" voltage provided by the Charge Wizard isn't really high enough to provide true equalization. It's only the 14.4V bulk mode voltage. So I wouldn't worry about it with AGMs.
Maurice
12-04-2004, 03:13 PM
no.
The first statement you make is true, but that is not what you said in you previous post. You said:
"This means that lower current draws will yield much better usable energy from an Optima that it will for most other batteries of equivalent weight."
What I am saying is that the effect is much more pronounced at higher current draws.
If you do the calculations using the Peukert coefficients that you provided, you get these results:
At low (3 amp) draw from 180 ah cells, the Optima will give 56 hrs reserve capacity, vs 48 hrs for a wet cell. The wet cell is 86% the efficiency of the Optima.
At high (25 amp) draw from the same cells, the Optima wil give 5.9 hrs reserve capacity and the wet cell will give 3.8 hrs. The relative efficiency of the wet cell is now only 64%.
Thats the point I was making, that at higher draws the Peukert effect is worse for wet cells than at low draws.
I think you will find the Lifeline AGMs have a similar Peukert coefficient to the Optima AGM, certainly less than 1.2 for flooded cells.
12-04-2004, 03:14 PM
2001 34' Limited
The State of
, Ohio
A typical 100 amp-hour battery, by definition, gives 20 hours at a 5 amp discharge. One might think that it would give 100/25 = 4 hours at a 25 amp discharge. Looking at the Reserve Capacity rating (time at 25A) shows this clearly isn't the case. Most 100AH batteries have a RC of around 180 minutes or 3 hours, which only equates to 75AH. That's the Peukert Effect.
With two 100AH batteries in parallel you don't have to worry about the Peukert Effect if you keep discharge at about 10 amps or less. However, at its rated output, a small 500W inverter will draw about 25A from each battery.
Maurice
12-04-2004, 08:58 PM
2001 34' Limited
The State of
, Ohio
I calculated the Peukert Capacity (Cp) and Exponent (N), from the specifications above, for the yellow top Optima Group 31 and the smaller Lifeline Group 27.
Optima D31 Cp=83.4 N=1.08
Lifeline Group 27 Cp=129.3 N=1.16
Time = Cp/I^N
There's no reasonable amount of discharge at which the Optima's lower exponent would help it equal the smaller Lifeline, due to the Optima's much smaller capacity.
Maurice
12-04-2004, 09:24 PM
Other sizes are slightly different. The Optima 34D has a coefficient of 1.11, and the Lifeline 24T has a coefficient of 1.15, close enough that I think personal preference or cost would be the deciding factor. I think I would prefer the Lifelines.
We need to keep in mind that the Peukert capacity is the capacity measured in a straight line to depletion. The 'missing' energy isn't wasted or lost. It just means that the voltage can't keep up with drawdown rate. If the battery is allowed to rest, it will recover the lost energy. It's a diffusion limited reaction.
12-05-2004, 06:32 AM
GStephens
1982 31' Limited
1953 25' Cruiser
Hamilton
I theorize that each of us has at least one area of retardation. In my case, understanding the mathematics and principals of the previous posts would certainly be one of my areas. I have no problem in giving a speech before 1000's of people. I can recite most everything you would ever want to know about artificial insemination, embryo transfer techniques, and/or cloning of embryos with regard to bovine reproduction. I keep abreast of governmental, political, social and enviornmental issues both domestically and abroad. I have little trouble understanding 99% of the issues I see discussed here on the forum and often have found myself wondering how some people can seemingly be so dense at understanding some of the advice given here. On this issue, however, I find I am one of those dense people. I become totally lost in trying to comprehend the Peukert factor, exponents, relative efficiencies and to be able to truly comprehend the relative merits of utilizing one battery over another in the context of this discussion. I'm just grateful that there are those who do understand the concepts for which I find myself lacking.
GStephens
