Old 02-06-2021, 06:06 PM   #1
2021 27' Globetrotter
Mount Pleasant , Michigan
Battery Cable Gauge
Good Evening
Installing a Victron SmartShunt to the battery bank of my 2021 GB 27FBT. I need a small section of cable to connect the shunt to my battery but I am currently not with the unit and need to know what gauge wire was used off the negative post of the battery?
Thank You
2021 Globetrotter 27FB Twin Copenhagen Cream ~ On Order
2020 Ram 2500 Laramie 6.4 B&W 7" Drop Hitch
2019 FC 19CB ~ Sold
2012 Ford Explorer ~ Retired
"I don't know Margo"
TrailDude is offline   Reply With Quote
Old 02-06-2021, 06:13 PM   #2
waninae39's Avatar
2017 22' Sport
NCR , Ontario
use the biggest size cable ( ie low gauge #) that you can get. start with 10 ga at least
waninae39 is offline   Reply With Quote
Old 02-06-2021, 06:40 PM   #3
2018 25' International
Slidell , Louisiana
If you have a 1000 W inverter and a 50 A fuse on the feed to the distribution/power center, and you are going from the shunt to one post and then using a jumper to the other post go with 1 AWG 90C if you happen to find some 115C wire 2AWG will work. If you are immediately splitting to more than one battery, you can go with 2 or 4 AWG 90C insulation.
Old 02-06-2021, 06:44 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Battery Cable Gauge
Airstream ship with 6ga from batteries to 12v bus and 4ga from batteries to inverter.
When I re-wired mine I used a single 1/0 AWG cable to be sure. Both pos and neg. That is way more than enough for stock inverter and 12v needs.
Hope this helps.
wulfraat is offline   Reply With Quote
Old 02-06-2021, 06:51 PM   #5
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Anything I do between the batteries and inverter, I use 4/0 gauge, but I have a 3000 watt inverter and I always over engineer... (and future proof).
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 02-06-2021, 07:09 PM   #6
2007 22' International CCD
Dave, you are obviously another member of the Overkill Engineering Department!
rmkrum is online now   Reply With Quote
Old 02-06-2021, 10:01 PM   #7
dznf0g's Avatar
Oswego , Illinois
It is a wise and elite group. Doesn't cost a lot and indeed future proofs.
I always go at least one wire gauge larger that calculations indicate.
-Rich-
Old 02-07-2021, 06:25 AM   #8
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Thanks, guys! I am honored!
DaveP
Cut-Off Switch for House Battery: Install on the Negative Cable or Positive Cable? Searching Batteries, Univolts, Converters & Inverters 27 04-18-2020 06:08 PM
Wire gauge from Battery to Converter Sairaf Batteries, Univolts, Converters & Inverters 9 01-07-2013 08:39 PM
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
How long can my battery cable be - and what gauge wire? robwok Electrical - Systems, Generators, Batteries & Solar 3 10-20-2011 09:52 AM
Battery cable gauge Robin Stone Batteries, Univolts, Converters & Inverters 5 03-04-2008 07:52 PM
