Old 02-28-2021, 08:44 AM   #1
JFTKSU78
jftompkins's Avatar
2017 23' Flying Cloud
Olathe , Kansas
Battery box - damaged AGM casing
I discovered through my careless retrofit that my Lifeline 4GPL-4CT battery casing was rubbing up against the three rivet protrusions holding the Zamp solar port. Even with batteries righted down - as best I could with center post. This could have been a disaster of exposed cell going to ground Click image for larger version
ID:	389535but caught in time after pulling my batteries for winter. I did a PVC patch on battery side wall which had not been breached. Have some galvanized flashing than am going to slide in between battery casing and rivets OR re-rivet from outside in. There is so little clearance that any movement those rivets seem
to dig at the battery casing.
jftompkins is offline   Reply With Quote
Kitchen Window Casing / Surround? Bartowski Upholstery, Blinds, Walls & Interior Finishes 1 05-28-2019 03:23 AM
New 214 AH AGM 6Volt fits Battery Box Vantair Electrical - Systems, Generators, Batteries & Solar 11 07-05-2018 09:50 AM
Battery AGM (4) 6V GC2 vs (2) AGM 8D Torpedo Family Land Yacht/Legacy Motorhomes 3 11-15-2012 05:35 PM
'74 Argy Rear Light Casing Chopper Lights - Interior & Exterior 3 09-09-2006 06:21 PM
Air Conditioning Casing Mobile1 Furnaces, Heaters, Fireplaces & Air Conditioning 2 02-26-2004 10:10 PM
