Old 06-08-2021, 02:44 PM   #1
2019 23' Flying Cloud
2018 22' Sport
LittleCity , Colorado
Batteries only charge to 12.9 volts
Hi, I'm wondering if I've damaged my batteries ... when hooked up to shore power (at my house, prior to going camping) my batteries seem to top out at 12.9 volts ... thus, based on my understanding with 13v being 'full' or '100%' I'm never able to get a 'full' charge ...
Should I replace my batteries or is the normal?
Thank you!
El Juncal is offline   Reply With Quote
Old 06-08-2021, 04:17 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
What sort of batteries do you have? If they are flooded cells, first thing to do is to check the fluid levels. If they are AGM's, there is no way to do that.
How long have you let things run? It will take *hours* for the batteries to go from empty to full. A 24 hour charge is a good idea at the start of the season.
How are you checking the voltage? The stock voltmeters *do* go nutty. Best to check at the battery terminals with a multimeter. If you don't have one yet, head over and spend $30 on one. ( Yes, you can spend more and get better versions, a $30 meter will do just fine in this case).
What happens if you disconnect one battery? What happens if you disconnect the other? ( assuming you have two ). If the voltage pops up when you disconnect one ... yup... that's a battery problem.
If you still are wondering, pull the batteries and take them over to get tested. This could easily be a blown converter / charger ....
If you do replace the batteries ( .... if you have two ...), you should replace both of them at the same time.
Lots of twists and turns ... sorry about that !!
uncle_bob is online now   Reply With Quote
Old 06-08-2021, 06:47 PM   #3
2017 25' Flying Cloud
Raleigh , NC
You did not mention what type of batteries you have. Assuming your camper is plugged in, and you unplug it and then immediately read that you are at 12.9 v, you are reading your batteries with a draw on them that drops the voltage (all the background stuff such as refrigerator, propane detector, etc.).
I have AGMs and at 100% charge, they will read 12.9 volts when I disconnect.
To get an accurate fully charged voltage, you would pretty much have to disconnect the batteries and then take a voltage reading to see an accurate charge state based on volts.
JoeHTP is offline   Reply With Quote
Old 06-08-2021, 08:10 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
12.8-12.9v is a very good thing for lead acid batteries. Technically 12.6v at rest with no loads is "full" for most brands.
wulfraat is online now   Reply With Quote
Old 06-08-2021, 08:32 PM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I've got 2 new Interstate flooded batteries. I know that once they come off the charger and sit for a bit they settle down to 12.9 volts.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 06-09-2021, 07:40 AM   #6
2018 22' Sport
Hi
Hi, Yes, I have two AGM Group 24 12v batteries in parallel. This morning I disconnected the shore power, turned off the battery usage switch (located in my trailer) and then used a multi-meter to check voltage. I get 13.06 on one battery and .. 13.1 on the other ... which is super cool (I suppose!) as this must mean my batteries are 'ok'.
Now however, the 'battery level' check in the trailer (when pressed) reads 12.6 (this with everything turned off and no shore power connected).
Why would by SeeLevel display not know the correct voltage on my batteries?
Old 06-09-2021, 07:50 AM   #7
ITSNO60's Avatar
Tucson , AZ
Once the batteries are fully charged and disconnected from everything you need to let them rest an hour or more for an accurate un-loaded reading. They are probably not over 13 volts but 12.6-12.9 as mentioned which is right where they should be. The See Level device puts a load on the batteries as well as the battery switch being on can allow for other loads to be present. Also the See Level battery monitor is not the greatest and will be affected by loads, a true shunted battery monitor is best if you want to know exactly where you are at.
Brian
ITSNO60 is online now   Reply With Quote
Old 06-09-2021, 07:55 AM   #8
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
As mentioned above, I think your batteries are fine. My AGMs tend to show 13.6V when connected to shore power, but after I disconnect and they settle down, they show 12.9V.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 06-09-2021, 11:51 AM   #9
2015 27' Flying Cloud
Olympia , Washington
My fairly new flooded lead acid top out at about 12.7 after relaxing from a full charge. I’d say 12.9 is unusual unless you just shut off charging.
Pat.Mann is offline   Reply With Quote
Old 06-09-2021, 02:10 PM   #10
Half a Rivet Short
Hi
The SeeLevel stuff can be wrong for a variety of reasons. The simplest one is that they do break ....Being off by 0.2V in either direction is not that unusual.
Old 06-09-2021, 02:55 PM   #11
dznf0g's Avatar
Oswego , Illinois
There are a variety of reasons. The long run, from the batteries to the wall location offers resistance. Each connection in that run offers more resistance. The circuit to the SeeLevel (in my unit) runs from the battery, through a breaker to the positive buss bar, to distribution panel then out on a non-dedicated circuit....some 24 feet or so to the rear of the SeeLevel. All of that creates a voltage drop, due to resistance.
All that said, mine only shows a 0.1V drop when compared to my Victron and Tri-Metric readings.
My anal retentive nature would make me hunt for the cause of your difference.
-Rich-
Old 06-09-2021, 03:08 PM   #12
ITSNO60's Avatar
Tucson , AZ
If you are using the See Level or similar device, or a multimeter, you are seeing the charging voltage, not the actual battery voltage.
Brian
Old 06-09-2021, 03:23 PM   #13
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
I would agree ....on my sea level I get up around 13.6 while charging and around 12.6-12.7 at rest after a charge.
rucos is offline   Reply With Quote
Old 06-10-2021, 06:20 AM   #14
Raleigh , NC
Even with your switch in the store position, your propane detector stays on, potentially other draws, which means you are not getting a true "at rest" reading like you did when you disconnected the batteries.
I have a Merlin Smartgauge with dedicated cables to the battery terminals, and it always gives me a higher voltage reading than the Airstreams built in voltage gauge...I suspect for the reason others have said, length of run, resistance in connections etc.
Old 06-10-2021, 06:24 AM   #15
Dennis C's Avatar
Iím not. Iím using a Zamp charge controller that shows battery state of charge.
Dennis
Old 06-13-2021, 09:11 AM   #16
2018 30' Classic
Lake Charles , SW Louisiana
If not mistaken, When connected to shore power, the battery charge rating your seeing is being controlled by your inverter/charger.
"Finding the Roads that Await Us!"
Rick & Lydia Williams
rewillia is offline   Reply With Quote
Old 06-13-2021, 09:50 AM   #17
Chesterville , Ohio
Using voltage alone to determine state of charge is flawed unless you allow the batteries to rest, not charging or discharging, for several hours. A shunt is a much better tool to monitor batteries so you can see amp hrs in and out.
Flat_twin is offline   Reply With Quote
Old 06-13-2021, 12:04 PM   #18
flyfshrmn's Avatar
1975 25' Tradewind
Woodland , California
Depends on the battery, how it's connected, how you measure, and the charger. I have found most chargers will not charge a deep cycle battery beyond 12.9 volts. The same chargers will charge a good automotive battery to between 13.1 and 13.7 volts
flyfshrmn is offline   Reply With Quote
Univolt is only putting out 6.3 volts jack9443 Batteries, Univolts, Converters & Inverters 7 04-14-2015 08:23 AM
No power to the 12 volts and batteries have completely discharged. atomeve Electrical - Systems, Generators, Batteries & Solar 31 01-07-2014 07:29 PM
How many volts in trickle charge line - 1968? BuffaloJoe 1965-1969 Sovereign 13 05-27-2013 09:58 AM
1 of 3-12 volt sockets getting only 12.16 volts? squashy Electrical - Systems, Generators, Batteries & Solar 2 08-29-2011 07:48 PM
6 Volts Golf cart batteries marchesi Batteries, Univolts, Converters & Inverters 11 06-10-2009 04:42 PM
