Old 07-02-2020, 08:30 PM   #1
2015 25' FB International
San Ramon , California
Batteries Loosing Charge
Hello All,
We live full-time in our AS. Plugged in.
So I have been having trouble with the original Atkinson charge controller for a few months now. Intermittent clicking on and off. Have been meaning to upgrade for the past 2 months. but....
While being plugged in there never seemed to be a problem with the batteries. Lifeline AGM's 5.5 yrs old
Last week, when we were boondocking, the batteries weren't charging. Even when I had the AS plugged into the genie.
Batteries were slowly getting drawn down.
Once we got back home, and plugged back into shore power, still not charging.
Checked all the wiring, seemed fine.
Charge controller continued to click intermittently.
Decided to order new charge controller and pick up new batteries.
Replaced with the same Lifeline AGM's and an Epever Triron 4210 charge controller.
Wired everything up and things are running great.
BUT....
Batteries are still not charging.
What am I missing?
Any help will be greatly appreciated.
Kalidas is offline   Reply With Quote
Old 07-03-2020, 05:01 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
The 'charge controller' does not supply the juice to charge the batts.
Has the circuit breaker for the converter/charger tripped?
Good Luck...
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Worry...a brain exercise done when it really wants to sleep"
RLC
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 07-03-2020, 05:39 AM   #3
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
It looks like the Epever Triron 4210 is a solar charge controller, which isn't related to what charges the batteries when you are plugged into shore power or your generator. As mentioned, check your converter/charger - probably part of where the breakers and fuses are located.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is online now   Reply With Quote
Old 07-03-2020, 12:55 PM   #4
I have checked all fuses and breakers.
The PV panels are now charging the batteries, but it still doesn't look like the batteries are pulling any power from the shore power.
Though I am able to run all electrically from the shore power.
Old 07-03-2020, 12:56 PM   #5
I have also checked the battery terminals. Everything is tight
Old 07-03-2020, 03:39 PM   #6
What are the readings on the Monitor?
System on solar....................System on SP
ID:	371861   Click image for larger version
Molly Ivins
RLC
Tahawus
Old 07-03-2020, 06:01 PM   #7
Here are the reading on the monitor
Not sure if this is the way to upload pics
ID:	371883   Click image for larger version
ID:	371885   Click image for larger version
ID:	371887   Click image for larger version
Old 07-03-2020, 06:01 PM   #8
Oops....guys I need to rotate the pics...
Sorry
Old 07-03-2020, 10:30 PM   #9
Is it possible that the converter is shot?
Old 07-05-2020, 06:48 PM   #10
We limped through the weekend. Hopefully be able to talk with a professional in the morning.
Batteries being kept topped up with solar during the day, and trickle changed overnight.
Old 07-06-2020, 10:40 AM   #11
2016 25' International
Los Angeles , California
@Kalidas,
I hope you don't mind my piggy-backing on your thread -- I'm having much the same problem, although I don't have your more sophisticated monitoring capability. Everything I have read suggests that the Parallax electronic power converter has failed (there are no blown fuses, etc.)
In addition to shore power not recharging our batteries (two AGMs), our ZAMP Solar Controller monitor shows that the two 100w flex solar panels we have are no longer providing power to the batteries either. I currently have the batteries on a trickle charge, but with no apparent improvement to the charge level. (Unfortunatelly, I'm so electronically challenged that I'm not even sure I'e connected the trickle charger properly to the batteries.
If you are able to reach a professional today, or in the near future, I hope you will post your findings on this thread. I have called a couple of Airstream service centers as well, but have not yet received a callback.
Bdinla is offline   Reply With Quote
Old 07-06-2020, 10:59 AM   #12
Ray Eklund's Avatar
2019 27' International
2014 25' International
Fort Saunders , Wyoming
Bdinia: Flexible Solar Panel Failed after Three Years on my RV
Very good explanation and way to test. Maybe this video and comments can help. I found it interesting and do not have flexible panels, but the Airstream Dealer had them on display.
The flexible attached directly to the roof of our Airstreams will not permit air to flow underneath to cool... from reading some responses on this Thread. I was curious and going to finish reading this well done post with explanations while in the process of discovering the Panel was Bad.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 07-07-2020, 11:20 PM   #13
Luigi123's Avatar
2018 30' International
2014 30' Flying Cloud
Los alamos , New Mexico
My AGM batteries failed me in two years as of today on my 2018 30'Serenity. I heard the factory has a bundle of aged batteries, I guess my $93,000 trailer was free, the real cost was the batteries- no worries caught the issue at home. Just another notch on the report card for decisions down the road.
Luigi123 is offline   Reply With Quote
Old 07-08-2020, 05:01 AM   #14
That IS unusual.
What brand AGM's? Our Lifelines lasted 11yrs.
Most AS battery failures can be traced back to the converters being used. The Parallax in Cloudsplitter cooked two pair of Interstates. The batts could not tolerate long charge cycles on shore power without human intervention.
Even the 'upgraded' converters being used in the newer AS's seem to have left something on the table.
Upgrading the P-Lax was the first upgrade we did in the 2nd year of Stream'n. Not really all that expensive for the POM it provides. The IOTA that replaced the P-Lax lasted 12yrs. (until the Lithium upgrade.)
Molly Ivins
RLC
Tahawus
Loosing power when water pump or furnace kicks on. CBabbs Batteries, Univolts, Converters & Inverters 8 10-16-2018 03:47 AM
Solar charge controller affect charge from converter? fran&frank Electrical - Systems, Generators, Batteries & Solar 1 03-22-2016 10:39 PM
Charge wire on 7-pin, what demands does AS need and how does this charge starcraft Batteries, Univolts, Converters & Inverters 10 04-20-2012 08:38 AM
Full Charge - No Charge! Cracker Batteries, Univolts, Converters & Inverters 2 06-22-2007 02:04 PM
Keeping the telltale while loosing the Univolt Excella CM Electrical - Systems, Generators, Batteries & Solar 0 06-04-2006 06:09 PM
