Old 12-25-2017, 01:09 PM   #61
knunut's Avatar
Chgo. N.W. Burb's , Illinois
Was at JC in Oct. with bad converter they would "NOT"upgrade.(2016 Trailer).They said it was Diff.size requiring diff. front panel for cabinet!!.Even offered$$$$ to do it.
knunut is offline   Reply With Quote
Old 12-26-2017, 11:16 AM   #62
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
I assume you are saying JC would not replace your bad converter with a multi-stage converter like the Parallel Dynamics, Boondocker, or their new WFCO multi-stage converter for "free" on your 2016? Did they replace your bad converter??
There are many converters, and some dealers do install a new mounting rack when they replace the OEM single stage converters with a multi-stage replacement converter as an upgrade. This does cost money typically. Some of us did this ourselves to save money. My friend just paid for the cost of the converter in his 2017 23, around $300~ and the dealer installed as he had bad converter. Did you talk with the warranty folks at AS?
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 12-26-2017, 03:24 PM   #63
knunut's Avatar
They did replace with same oem model. However would not upgrade even if I paid ???
Old 12-27-2017, 06:48 AM   #64
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The newer multistage converter is a different size than the older multistage converter. There is no "stock" cabinetry that puts the newer multistage into the older trailer.
uncle_bob is online now   Reply With Quote
Old 12-27-2017, 12:54 PM   #65
gypsydad's Avatar
I called my dealer service guys just now. For your 2016 26U, one of the "recommended" multi-stage converter replacements for the OEM single stage converter is the Progressive Dynamics 4600 for the 30 amp or the 9200 model for the 50 amp. AS dealer I talked with said with installation, it was about ~ $600 for the 30amp and $960 for the 50 amp, since there is more work involved including a mounting chassis, according to this tech. He said the 50A amp was a bit more work, thus the price difference.
I know your in IL, but perhaps you can discuss with your local AS dealer to confirm. and see what they would charge? ..hope this can help you.
The other option I would highly suggest is calling Randy at Bestconverter.com 888-828-1893. He helped many of us and can supply Progressive Dynamics models or Boondocker, or other multi-stage converters which will work, and also discuss your model AS mounting challenges. Good luck!
Old 12-28-2017, 06:57 AM   #66
Half a Rivet Short
Hi
The older multistage converter is essentially the same as the newer multistage converter. There are a *lot* of places you can buy other converters from. As you may have noticed, one particular outfit seems to have a cheering section that is devoted to spreading their name around. Consider the accuracy of the rest of what they say as you evaluate their recommendations ....
Old 12-28-2017, 09:51 AM   #67
gypsydad's Avatar
Hi
Aside from your instance that the OEM single stage converters are "essentially the same" as newer multi-stage converters, you bring up a good point UB; I agree. Have you, UB, found any of "their" data to be inaccurate? If so, please do share...
FYI- received good replacement purchase/installation advice from AS service guys in Fairfield CA, AS factory in JC, and also from Randy at Bestconverter. Worked well for me and looks like many others also had a good experience. Today, you can find out a lot about reputation of a company on the Internet, if you care to look.
http://www.bestconverter.com/Testimonials_ep_19-1.html
But, if you know of any issues please share with us; that's what this Forum is for...helping each other out.
Old 12-29-2017, 07:17 AM   #68
Half a Rivet Short
Hi
The converters have been correctly described as multi stage by their manufacturers for years now. Thus that is *not* the issue. If it's the *only* point of distinction between the "greatest in the world" and "absolute junk" then ... then something is being missed.
Very simply put, there are other parameters involved in a charger. They can make some difference. If you focus on parameters that actually are the same between the chargers, you are completely missing the point.
Old 12-29-2017, 08:01 AM   #69
2017 19' International
Tallahassee , Florida
Further update ...
OK, I hooked up the battery tender. It charged for most of a day, then switched to maintenance mode. Working as expected.
Still donít know what was at fault. Did the batteries have bad cells? Did the converter run amok?
Apparently there is no way to test the converter, at least at the DIY level.
Looked into a replacement, but for now Iím sticking with the stock charger.
Will be out camping in early February, and battery performance on that trip may settle the question.
WhereStream is offline   Reply With Quote
Anyone put lithium batteries into their Bambi? larry9000 2005 and newer - Bambi all models 50 07-10-2020 05:18 PM
Newbie bringing AS from our place in Canada to our place in the US for the first time cyclistream 1974 - 1977 Overlander 9 03-29-2017 07:02 PM
Back from our first time out! monkeypants Our Community 11 05-10-2009 09:46 AM
our first time out candycane Our Community 2 10-28-2006 05:41 AM
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 08:55 PM
