I'd like to get back to the OP's questions, because I'm in the same predicament. We are picking up our GT25 next week (woohoo!!!) and, for whatever reason, Airstream has decided to not include batteries so we have to choose.
My assumption is because so many people opt to jump right to lithium so Airstream has decided not to waste time and money on AGM either for cost savings to them or convenience for the buyer.
So...the fundamental question is...when I pick-up my trailer can I buy lithiums without having to do any mods as indicated by Airstream's blog post? I don't want lead acids, and given the choice between AGM and LiFe I'd rather just go lithium and be done with it.
The issue is that Airstreams, as currently designed and built, aren't optimized for lithium. The three charging systems for the battery (all the way back to their
sources) are shore power, TV, and solar (if equipped).
Shore power goes through the converter which can now supposedly handle any battery chemistry automatically. Can it? I don't know. I'm not sure what the new converter model is. Not that I don't trust Airstream, but I do plan to verify.
As delivered, the TV connects directly to the
12V bus through the 7-pin. As Richard explains above, that's not optimal for lithium. At best, you won't get much of a charge. At worst, you might damage the batteries.
As for solar, if the solar controller is still a Victron MPPT it can handle lithium just fine. You (or the dealer) has to change a few settings. No big deal so I don't consider this a mod.
So...you can have the dealer put in lithiums at delivery without mods IF...
1. The new converter can actually handle lithiums (either by auto-detect or manual configuration).
2. You follow Richard's advice above and learn to live with poor TV charging or disconnect it.
3. You change the solar controller's settings to lithium.
After that, you can do all sorts of mods to optimize for lithium (Multiplus, DC-DC converter, etc). Or...you can just have the dealer do them prior to delivery which is probably where the OP's $3010 quote comes in.
For us, if the three caveats above are met we plan to buy lithiums and defer the mods for myself (once I feel comfortable with the trailer) or for someone like AM Solar.
