RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-22-2020, 02:12 PM   #1
2019 23' International
Portland , Oregon
Batteries died at dealer
I took my 2019 23FB to the dealer for some warranty work. It was there for about 2 months due to a protracted fight with HQ about the warranty. When I picked it up the batteries were at 7.5V. Took them to Interstate after charging them. One is dead, and the other is likely dead. It's on the reconditioning charger. Of course they are just out of warranty. On the way home I thought "OK, not so bad, I can upgrade to 6V". Then, I looked at the prices for that.
Ugh. I heard that AGM batteries are resistant to damage due to deep discharge? Is that true? Any experience here?
Note: I have a progressive dynamics 4 stage converter, and a disconnect on each battery, which I guess I'll need to use every single time I go to the dealer
2019 International Signature 23FB "Cecil"
2005 Yukon XL
Former coach: 2015 Bambi 16 "Beanie"
leedav is offline   Reply With Quote
Old 11-22-2020, 02:16 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
If you let any lead acid battery, AGM, flooded or otherwise hit 7.5v it will never function the same again. You should avoid discharging any lead acid battery below 50% / 12.2v - AGM, flooded or otherwise. If you repeatedly discharge more than 50% you will absolutely shorten their working lifespan.
Dealer should replace the batteries after their mistake, especially with the convenience you’ve provided with after market disconnects.
wulfraat is offline   Reply With Quote
Old 11-22-2020, 02:18 PM   #3
Portland , Oregon
Agree
2005 Yukon XL
Old 11-23-2020, 01:40 PM   #4
Any day now....
jaybauman's Avatar
2019 30' Flying Cloud
Katy , Texas
AGMs can handle deep discharge much better than flooded lead acid batteries. An equalization charge might even bring them back close to what they once were.
But there is no free lunch. Even if you are able to get a proper open circuit voltage with them, this low voltage excursion will have reduced the quantity of cycles remaining in your batteries.
2019 Flying Cloud 30FBB
Bunkhouse is sold...something more "classical" on order!
2020 GMC 3500HD Duramax AT4
ProPride 3P w/ 1400 lb. spring bars
jaybauman is online now   Reply With Quote
Old 11-23-2020, 01:56 PM   #5
Long Island , New York
Originally Posted by leedav View Post
Agree
x3!
"Let the Music Lift You Up"
Peter
OTRA15 is online now   Reply With Quote
Old 11-23-2020, 02:19 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
SNIP QUOTE()<><)Note: I have a progressive dynamics 4 stage converter, and a disconnect on each battery, which I guess I'll need to use every single time I go to the dealer....
With note on the switch telling them.
TURN OFF WHEN NOT USING
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
“Change is the new normal, if nothing changes, nothing is normal, everything changes, everything is normal.”
RLC
Tahawus
Old 11-24-2020, 04:41 AM   #7
Mo' Bettah
May be mo' bettah to turn off batteries before you leave, and have the sign say something like "turn on temporarily for work, and then turn back off !!!"
Peter
Old 11-24-2020, 07:26 AM   #8
2020 23' Flying Cloud
Sebastian , Florida
Good luck with having the dealer turn a switch on or off. Protecting the battery is not rocket science! A $10 extension cord will save $300 or more of batteries, but they don’t care because they get away with the customer eating the cost of replacement, or even profiting from an “unexpected “ sale. Hold their feet to the fire!
-Don
(That man in that tiny can)
(Same man, Bigger can)
GetawA-S is offline   Reply With Quote
Old 11-24-2020, 07:42 AM   #9
Well, you could always take the batt's home with you.
Molly Ivins
RLC
Tahawus
Old 11-24-2020, 08:44 AM   #10
Sebastian , Florida
Well, you could always take the batt’s home with you...
Not bad advice. Would any dealer provide the labor and hand cart to assist?
-Don
Old 11-24-2020, 07:06 PM   #11
Portland , Oregon
Cold day in hell before I buy the replacements there
2005 Yukon XL
Old 11-24-2020, 07:07 PM   #12
Portland , Oregon
Yeah. And then have them plug it in and the dangling wires go BOOM
2005 Yukon XL
Old 11-25-2020, 12:30 PM   #13
Portland , Oregon
Are the batteries at Costco the same? They’re a lot cheaper
2005 Yukon XL
Old 11-25-2020, 12:57 PM   #14
s1000pre's Avatar
2020 25' International
minneapolis , Minnesota
My batteries were bad when I purchased the Airstream new. Of course Interstate swapped them out no questions asked under warranty. Then the batteries nearly died when I stored the trailer for 2.5 weeks. Either disconnect or take them out for long periods. I was blown away how fast they drain from the parasitic draw.
s1000pre is offline   Reply With Quote
Old 12-05-2020, 01:18 PM   #15
Portland , Oregon
Epilogue: dealer makes good. Batteries being changed out right now!
2005 Yukon XL
Old 12-05-2020, 02:13 PM   #16
2013 28' Flying Cloud
Penn Yan , New York
Batteries
I just replaced my 4 1/2 year old interstates. I researched for group 24 AGM’s and bought 2 Duralasts at Autozone. If you are a veteran they give a discount.
I wired a waterproof digital voltmeter in the battery box so I can monitor the battery’s voltage.
I have a disconnect switch on the batteries. With the disconnect switch and the house disconnect switch you can completely isolate the batteries. Works great.
delrossa is offline   Reply With Quote
One of the batteries died HiHoAgRV Batteries, Univolts, Converters & Inverters 3 08-22-2011 02:48 AM
12 Volt System died....Need help! Tikiman Electrical - Systems, Generators, Batteries & Solar 3 11-28-2005 05:32 AM
Power Converter Died??!! JimGolden Electrical - Systems, Generators, Batteries & Solar 5 11-17-2005 08:18 PM
Help and advise she died in the middle of nowhere saxonsraven Airstream Motorhome Forums 7 07-29-2003 08:10 AM
Refrigerator died James Schmidt Refrigerators 9 10-18-2002 11:59 AM
