01-27-2021, 05:56 PM
1972 27' Overlander
houston
Batteries and power converter
Hi, I've got a quick question, please.
My Optima AGM batteries are 110 amp and my power converter says it holds 100 amp. Are the batteries too much amperage for it?
01-27-2021, 07:35 PM
2004 25' Safari
2018 26' Flying Cloud
2019 25' Flying Cloud
North Central Texas
, USA
If you are talking about the CCA (Cold Cranking Amps) or the AH (amp hour) rating of the batteries that has nothing to do with the convertor's DC rating.
01-27-2021, 07:43 PM
1972 27' Overlander
houston
Originally Posted by brendamoran
I'm hoping the 100 amp is for max circuits out. We are less than 30 amp use. If it is for battery input, could we use a battery switch ?
01-27-2021, 08:14 PM
2004 25' Safari
North Central Texas
, USA
It sounds like you may be trying to equate the 30 amp AC input with the DC capability of your convertor and/or batteries. That's just my guess based on the question. For me a battery switch, solenoid activated or manual, is important.
This may be a little too complicated, at least for me, to be helpful through an online forum. I might suggest YouTube for some basic electricity vids. There are also some great videos on RV electrical systems.
01-27-2021, 08:16 PM
2018 25' International
Slidell
, Louisiana
Your power distribution center is rated for 100 amps max but there will generally be a 50 Amp fuse or thermal breaker on the lead from the positive bus limiting the max to the 50 amps. Your batteries are rated for 110 Amp Hr each in energy capacity and likely have a combined maximum output capacity of about 1200-1300 cold cranking amps, or over 8 times what is required to fry the distribution center. But don't panic, because the batteries will only deliver what is demanded from them. The fuse or breaker will protect the cables and the distribution center from any short that might occur. So no worries you are in good shape.
01-28-2021, 04:10 AM
1972 27' Overlander
houston
Thanks! That's an answer we were hoping for.
01-28-2021, 11:52 AM
1988 32' Excella
Robbinsville
, New Jersey
Another way to think of it is like asking the question. My truck averages 20 miles to a gallon and has a 30 gallon tank, will it flood the engine if I fill the tank?
01-31-2021, 06:27 PM
Bacliff
, TX
If your distribution center is 100A that is the max it will safely pass through. Your battery is 110Ah lead acid optima which means that you have a usable 55Ah of energy. After 55Ah is discharged, you will be in the 12.1-12.2v range (lower if the amp draw is higher). Basically, if you were to pull 100A, you would have about 1/2 hr before you get to the point where it will start killing the battery and about 1 hr brefore the battery is dead. Also, the more amps drawn the less amps you have - in other words, you do not get 110Ah out of a 110Ah battery if you draw 40A. If you plan to draw a lot of energy and boondock, then you might consider lithium batteries. If you hang at facilities with shorepower then it is no big deal. Remember that all lead acid (flooded, AGM, Gel, Optimas) all need to be brought to 90-100% charge regularly (preferably daily) to get maximum life and prevent sulfation. Keeping your batteries in a partially charged state for extended periods of time and to discharge below 50% are sure ways to kill them quickly.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Converter fan running... batteries fried... batteries replaced... fan still running!
hollycwright |
Batteries, Univolts, Converters & Inverters |
2 |
04-27-2020 04:41 PM |
New converter, batteries test good, without charger I loose power?
MissingLink5 |
Electrical - Systems, Generators, Batteries & Solar |
13 |
02-11-2020 09:23 AM |
No power to trailer from shore or batteries. Converter fried?
MarkHB |
7 |
07-09-2017 05:47 PM |
Best way to wire inverter/converter/shore power for seamless AC power
justgoclimb |
39 |
06-28-2017 05:51 PM |
Power Converter & Power Supply
Land Shark |
8 |
05-11-2010 10:51 AM |
