Batt charging advice asap?
I'm otr in CA and melted the SP connection. Likely some debris on/in the cord end not allowing for a good contact. Weather in mid 90's and running ac. Next am could not disconnect. New cord in hsnd, new as connection due tomorrow via amazon prime.
Running off coach batts and after 1st night, showed 12.46 on the meter.
I connected an 8 am charger directly to the battery, use switch is on. Just to conform this will not affect the powercenter since i have no SP and the charger is hooked directly to the terminal...diagonal posts connected. +/-.
Is this ok or a bad idea. This would allowme to keep the refer and refer fans running on 12cdc and gas. Part due tomorrow so this is a temp fix and don't want to run the batts down to low.
WashMoBob
