There are lots of things to consider... somewhat in priority order:
1) Have your batteries checked. As mentioned above, if they've been discharged one or more times to below 50% they may be permanently damaged.
2) Be sure your inverter is off when you're not using it. There is probably some sort of switch to activate/deactivate the inverter. If the inverter is on (active) it's working and using battery power even if you're not watching TV or using the inverted outlet(s).
3) Don't know the system you have installed in the Atlas for monitoring battery State Of Charge (SOC) but you need something that gives a true indication of the battery voltage, and power going in/out of the batteries. Typical RV battery monitors only show some sort of LED or 25/50/75/full readout. This is not a suitable means of really understanding the power in/out. If you have the simple system you need to upgrade.
4) RV manufacturers are required to install various safety devices in their products. Things such as carbon monoxide and propane detectors. These devices are certainly important when you are in the RV. But when you store the RV (long term storage) it doesn't do much good to power the detectors. Many RVers take time to install a complete battery disconnect, not just the store/use switch installed by the manufacturer, in order to fully disconnect the batteries when the RV is in long term storage. This is related to your battery drain issue because these phantom or parasitic drains are always present in your system unless you install a means to turn them off completely.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
