Old 03-03-2018, 01:59 PM   #1
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
AS 22FB- how many/type of Lithium can be install inside
I would like to replace my single ext. Lead acid AGm battery with 1 or 2 Lithium battery mounted inside
I would like to mount them under the Left side of the bed where the converter is located.
how many and what type of battery could i deploy
i want to get these for longer longer no-AC run time and and as I prepare for future Solar on the roof
waninae39 is offline   Reply With Quote
Old 03-03-2018, 02:34 PM   #2
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
The lithium batteries can be damaged if charged in freezing weather, although you can discharge them.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 03-03-2018, 04:07 PM   #3
waninae39's Avatar
NCR , Ontario
hello
TNX
yes, i take all battery & electronics out before winter parking
i also trickle charge the battery once/month
i am looking to replace 1 AGm with 1-2 inside Lion
Old 03-03-2018, 05:09 PM   #4
Boxite's Avatar
2008 22' Safari
Are you familiar with the nastiness of a lithium battery fire and how vulnerable they can be? Are you sure you want them inside the trailer with you?
Old 03-04-2018, 10:17 AM   #5
waninae39's Avatar
NCR , Ontario
only SOME types of Lion battery have that issue.
there are many different types of chemistry
the ones in your phone are NOT the same as those used in trailer applications.
do a wiki search on Lion and see also the OEM Lion vendors pages, they all explain the differences
cheers
Old 03-04-2018, 10:29 AM   #6
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
You have many options so it depends on the capacity you desire and how much you want to spend. Search the forums for examples of installs. I used a Lithionics battery and Victron components. Troutboy used Victron batteries and components. Others here have used Battleborn batteries. Check out the AM Solar website for packages and educational materials.
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 03-04-2018, 11:47 AM   #7
2011 22' Sport
Portland , Oregon
Most (all?) of the batteries being used for these applications are LiFePO4 formulation, and not the Lithium Polymer (LiPo) ones that are most sensitive/dangerous. The reality is that everyone's $300 "power vault" products that they buy on Amazon are likely far more dangerous than a lithium battery bank from BattleBorn or Victron. In the case of Victron, the safety factor really depends on the BMS you deploy...but even a badly managed LiFePO4 battery isn't nearly as dangerous as the cheap LiPo power devices sold on Amazon.
That being said, I installed one BattleBorn battery under the 22FB bed between the water heater and the 12V power distribution area...and I could probably fit a 2nd one if I decide to. Keep in mind that 1 BattleBorn 100Ah battery has more energy than 2 AGMs would. We had 2 lead acid Interstate batteries on the A-frame, and replaced them with the single BattleBorn which offers far more capacity. Since you can, at most, use 50% of the capacity of a lead acid battery we had at most 84Ah before, we now have 100Ah and shaved a lot of weight off.
You will also need to replace your power converter, otherwise it will be an endless guessing game as to the state of your battery and it will almost never be at 100%. What you do for charging your lithium batteries really depends on what batteries you go with, in the case of BattleBorn the PD4655 with lithium support is a great option.
I will say that when you do anything with a Lithium battery bank you really need to install an actual battery monitoring system (e.g. Victron BMV-712) as you cannot gauge capacity based on voltage at all...so any onboard monitoring will be useless. I mounted our BMV-712 next to our power disconnect switch under the front bed as well.
I keep meaning to write up our upgrade process, as it isn't just plug-and-play if you wish to actually fully benefit from the conversion. You can find a lot of threads on here on the subject, if you have any specific questions please ask.
SilverHouseDreams is offline   Reply With Quote
Old 03-04-2018, 12:46 PM   #8
waninae39's Avatar
NCR , Ontario
TNX SHD and others.
i bought the PD4655, just before they released the lithium option. i only had it for a few weeks.
i called and they will not accept it back or take it as a trade in, thus i have to eat the whole cost.
When the 22FB comes out of winter storage, i will measure up the area to see what i can put in. i would like to start with one lion . but measure and leave space for a second
Old 03-04-2018, 02:08 PM   #9
PKI
PKI's Avatar
Walnut Creek , California
Originally Posted by waninae39 View Post
-- snip -- thus i have to eat the whole cost. -- snip --
No, it is still a great upgrade for many. At worst you should be able to get half the cost back. Maybe a bit more if it's someone you can help install. A battery bank is a great idea, but somewhat beyond what most need unless they are extensive off grid campers.
A few side roads is just part of the adventure. Pat
Old 03-04-2018, 04:47 PM   #10
Olscot's Avatar
1976 31' Sovereign
Eagle Point , Oregon
TNX SHD and others.
Talk to Randy at Best Converter. Someone may be happy to buy your PD4655 to use with an AGM bank.
1995 F-250 ExCab Long Bed 7.3 Powerstroke 2WD
Metal Topper w/rack for boat usually full when camping
14 mpg Towing 17-20 Empty
1976 Sovereign 31' CB Rear Twin towed 'on the ball'.
Retired Professional Truck Driver 4 million accident-free miles. Various combo's GCVW 105,000 lbs 105' length.
Olscot is offline   Reply With Quote
Old 03-04-2018, 05:14 PM   #11
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
We have a 600 amp-hour lithium iron phosphate battery under the front sofa of our 2014 31' Classic. We have a 300 amp-hour lithium iron phosphate battery immediately in front of the street side wheel well and under the sofa of the dinette with no loss of storage space in our 2015 23D International Serenity. We use a Magnum MS-2812 in the Classic that has nine 100 watt solar panels on the roof and the hybrid Magnum MSH-3012 in the 23D with five 100 watt panels on the roof.
Old 03-04-2018, 11:38 PM   #12
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Keep the lithiums inside and use aquarium heat pads underneath if necessary. Mine are under the island bed and have stayed well above freezing for the last 3 winters with no pads.
guskmg
Old 03-07-2018, 06:47 PM   #13
waninae39's Avatar
NCR , Ontario
good idea to keep them warm
i have plant heaters from Lee valley. i could use them
so in the winter, use the solar to charge the battery and run the heaters under the battery, as the battery drains, the solar keeps it up.
Maybe ill try that next fall and see if my perpetual motion design works
New Lithium Battery / Inverter Install Rawn77 Batteries, Univolts, Converters & Inverters 19 05-11-2017 08:53 PM
Lithium Batt Solar Install 2015 Classic ghaynes755 Generators & Solar Power 54 12-14-2015 12:42 PM
1973 Airstream Land Yacht Sovereign -- Many Many Many Upgrades!!! eBay Watch Airstreams on eBay 0 06-18-2013 06:30 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
