Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-04-2021, 09:52 PM   #1
RMNummi's Avatar
2014 23' International
Saint Petersburg , Florida
Antigravity Lithium RV Batteries
Anybody using them? They are supposed to be plug and play. Iíve got a 2014 23D Serenity and they are supposed to be drop in to my battery box w no cutting.
RMNummi
2014 AS23D
TV #1 2017 Mercedes AMG GL63
TV #2 2017 Lexus LX570
RMNummi is offline   Reply With Quote
Old 11-05-2021, 07:41 AM   #2
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
According to their site, the battery group sizes are direct drop in. Never used them and never heard of them before today.
Question is, will the factory installed converter in the trailer be able to correctly charge it properly, my guess is no, but from what they state on the site, it's drop in at least in terms of physical dimensions...add a simple converter swap and you'd be off to the races.
https://antigravitybatteries.com/pro...tive/ag-27-rs/
panamerican is offline   Reply With Quote
Old 11-05-2021, 07:47 AM   #3
DaveP's Avatar
2004 28' Classic
Monument , Colorado
It looks like these batteries are intended for automotive use. Only 40 and 60 Ahs. And, they talk about cranking amps. I would talk to the manufacturer before buying for your trailer.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 11-05-2021, 08:15 AM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
They do make a deep cycle battery, but I'm not sure that it will fit in place of what's found in most Airstream trailers.
Richard
11018
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is online now   Reply With Quote
Old 11-05-2021, 08:54 AM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I did not know the anti gravity system needed a battery. Maybe that is why mine is not working.
Old 11-05-2021, 09:19 AM   #6
2007 16' International CCD
Somewhere , Colorado
Not sure these are ideal specs for powering the trailer, but to the extent there is any truth in advertising they might help with payload.
field & stream is offline   Reply With Quote
Old 11-05-2021, 10:24 AM   #7
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
There are "less expensive" and perhaps "better" alternatives for RVs out there check out Will Powers on YouTube who spends his life's goal testing these batteries. While I installed SOK's inside for $520 there are drop'ins as well that are "proven" for less then the antigravity. Besides - if I was to spend 0ver $900 I would go BattleBorn - just saying.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 11-05-2021, 10:28 AM   #8
DaveG's Avatar
Here and There , Pacific Northwest
It could be the molecular clutch or the glime ignitor?
DaveG is offline   Reply With Quote
Old 11-05-2021, 10:48 AM   #9
palm beach gardens , Florida
I read with interest the battery discussions and being in the boat business, batteries are very important. However, for 30 years of owning Airstreams I have always used the best conventional batteries for a fraction of what some people are spending now and I have had great luck with performance.
I think when I switched to all LED lighting, I have never had a problem with underperforming batteries. We boondock occasionally and have a 2200 Honda that handles any charging needs.
I am sure I will upgrade at some point but right now, I'm just not ready to spend a thousand dollars for batteries.
m rafferty is offline   Reply With Quote
Old 11-05-2021, 11:32 AM   #10
2017 23' Flying Cloud
Mesquite , Nevada
I have seen the Anti Gravity brand batteries for motorcycle and powersport applications but not for RVs. Anyway I bought 2 Lion Safari batteries from Costco, coupled with the 180 watt solar already on my trailer they perform very well. I did a plug & play installation, making sure the solar controller is set to AGM as it does not have lithium setting.
On a recent trip with no hookups, lows in the upper 30s running the furnace @ 68 I would check the voltage each morning and see 12.9 to 13.1 volts - had a long rain day with no sun so the batteries ran the heat 2 nights with no charge - still had 12.9 . My original AGMs would be nearly spent running furnace over night.
Ken G is offline   Reply With Quote
Old 11-05-2021, 11:34 AM   #11
2009 34' Panamerica
2005 28' Classic
For trailers of our vintage, you are spot on, however, new trailers coming off the factory floor being delivered to customers have much higher power demands.
The Classic has the most electronics in it, but even that isn't the 800lb ape in the room.....that is the 12v compressor fridge. The best conventional batteries might last a day, maybe two before they are depleted and they cannot be fully discharged without shortening it's life. Lithium batteries on the other hand, can be darn near full discharged without shortening the life and in many cases have equal or greater capacity than conventional lead acid type designs. Is the added cost justifiable? Really depends on the owner's lifestyle.
So although I agree with you fully, based on our situation with LP fridges and far less electronics, new owners of rigs starting across the trailer line for the 2022 model year and some that started to get the 12v compressor fridges in 2021 model year need more amp hours, much further discharge ability and some way to keep them charged (solar, generator, etc). Whole different beast IMHO.
Old 11-05-2021, 01:12 PM   #12
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
I had an Antigravity lithium battery in my Porsche street/track car. Much lighter than stock, obviously, and the built in bluetooth monitoring system was very useful. It also came with a remote control for activating the reserve power feature which could start the car if the main battery was exhausted. From my experience, the quality was good.
It appears they make a deep cycle 100Ah model which is priced more or less competitively and would be suitable for RV use assuming that it fits. I'm not offering an opinion on whether Antigravity would be the best choice (I have Battleborns in my Airstream) but they could be a legitimate option.
https://antigravitybatteries.com/pro...age/dc-100-v1/
Mike
2020 25' Globetrotter Twin | 2017 F250 4x4 6.7 max tow Platinum
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
mikeinca is offline   Reply With Quote
Old 11-05-2021, 01:28 PM   #13
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
It's obviously how they keep the weight down.
2019 Ford Expedition Platinum
Old 11-06-2021, 06:35 AM   #14
2018 27' International
Charlevoix , Michigan
I have used the Anti Gravity batteries in Harley motorcycles with very good experience so far. Way lighter than lead acid and much less temperature sensitivity than the Harley lithium which I also used. I may put a set of these in my AS 27 FBT next season. Probably will need to swap converter???
boater1 is offline   Reply With Quote
Old 11-08-2021, 04:25 PM   #15
KK4YZ's Avatar
2020 28' Flying Cloud
Hiawassee , Georgia
or the flux capacitor?
KK4YZ is offline   Reply With Quote
Old 11-18-2021, 01:04 PM   #16
RMNummi's Avatar
You guys r so funnyÖÖ
RMNummi
2014 AS23D
Old 11-26-2021, 03:26 PM   #17
RMNummi's Avatar
Went with Renogy for the batteries due to only lithium that would fit in old style battery box.
RMNummi
2014 AS23D
Old 11-27-2021, 08:00 AM   #18
KK4YZ's Avatar
Hiawassee , Georgia
Just curious. What did you do for the rest of the system? (Converter, etc). I believe your 2014 has a single stage converter (charger) and certainly not optimized for LiFePO4 batteries.
Old 11-27-2021, 10:21 PM   #19
RMNummi's Avatar
Contacted Parallax and purchased their modification to support lithiums. Turns out it takes the same part as the WFCO.
RMNummi
2014 AS23D
Lithium Batteries? galvestongrl Sprinter and B-van Forum 76 10-03-2018 06:23 AM
Lithium Iron Phosphate Batteries GenXair Batteries, Univolts, Converters & Inverters 39 06-06-2015 09:59 AM
Lithium Batteries for Solar ghaynes755 Generators & Solar Power 26 01-13-2015 10:02 AM
Electrical, Solar, Lithium Batteries on 28' International wbrown Electrical - Systems, Generators, Batteries & Solar 25 09-13-2014 07:44 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
