Old 12-22-2021, 11:44 AM   #1
Bellingham , WA
Alternator not charging
I recently had 4 battle born GC2 and a Victron solar Charge controller Mpp 100/30 installed in my 2018 Interstate. For some reason the alternator does not charge the batteries.
Any ideas
romanf17 is offline   Reply With Quote
Old 12-22-2021, 12:01 PM   #2
1976 Argosy 28
Warrenton , Virginia
It's possible
It's possible you need to look into a DC to DC converter for your tow vehicle.
Most newer trucks have super high output alternators but don't actually send much if any to the trailer in the way of charging amperage and for this they make what's referred to as DC to DC converters which usually take really large wires (Like welding wire size) and connectors to get any serious juice to the trailer.
Just an idea as I'm no expert and never even played one in a movie, so all my advice is well worth what you paid for it.
Do a search for the converters and see if this will solve your needs.
captainkirk is offline   Reply With Quote
Old 12-22-2021, 12:05 PM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Capt Kirk
It’s an Airstream Interstate van per member profile. Not a Dodge Ram rattler.
Yer camping buddy in SC
Unless I’m way way way out in left field.
Gary
GCinSC2 is offline   Reply With Quote
Old 12-22-2021, 06:25 PM   #4
1988 32' Excella
Robbinsville , New Jersey
I believe I have seen posts about new Interstates having DC to DC converters from the factory so they could charge lithium batteries and isolate chassis battery when engine is not running. So while captiankirk's advise is out of context it is still good.
EDIT; I believe the posts were about them not working correctly because they were not setup correct from the factory.
Old 12-23-2021, 04:12 AM   #5
1976 Argosy 28
Originally Posted by GCinSC2 View Post
Capt Kirk
Gary
Thanks Gary I hadn't noticed that it was a van my bad....
Old 12-23-2021, 12:58 PM   #6
Bellingham , WA
Yes - it is a As Interstate GT 2018. I too have seen some post about needing a Dc-dc converter, but it apparently was only needed for certain type of alternators- and I don’t know if the 2018 AS which is based on 2017 Meecedes Sprinter 3500 needs one. The shop who installed my bb batteries has not run into this ( they are highly recommended for van conversions).
How to not blow up your alternator charging Lithium daleyocum Electrical - Systems, Generators, Batteries & Solar 6 01-05-2021 09:38 PM
House battery not charging from alternator naner Sprinter and B-van Forum 65 08-22-2017 05:42 PM
Wiring a separate alternator for charging trailer batteries Streamside Batteries, Univolts, Converters & Inverters 12 01-04-2012 08:24 PM
Charging from alternator Bohemian Batteries, Univolts, Converters & Inverters 5 10-10-2011 07:32 AM
Charging with TV Alternator baby_beluga Batteries, Univolts, Converters & Inverters 4 05-20-2011 10:13 PM
