RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-24-2021, 09:47 AM   #1
2019 25' Flying Cloud
Northfield , Minnesota
All inverter outlets not working
2019 FC RTB. Dewinterized, battery working.
No power to inverter outlets on shore power or battery power, though inverter led light does come on.
Fuses checked, circuit breaker all checked and good.
Is there reset button on inverter? Where is it located?
jroetzel is offline   Reply With Quote
Old 01-24-2021, 09:54 AM   #2
JEB
2021 23' Globetrotter
Lisle , Illinois
Make sure the inverter is completely off. No LEDs at all. Inverter display should have no lights lit. Now check the outlets. If still no power, go to the breaker panel and find the one that controls the inverter outlets. Switch it to off. Then switch it to on. Then check the outlets again.
JEB is offline   Reply With Quote
Old 01-24-2021, 09:59 AM   #3
2018 25' International
Slidell , Louisiana
There is an output breaker with a manual reset on the inverter if you have the WFCO inverter. The troubleshooting section describes it. If resetting the breaker does not fix the issue, the guide indicates the inverter is internally damaged. The switch/button is on the back in the upper right above the RJ-22 jack.
Old 01-24-2021, 10:25 AM   #4
Thanks. We cannot get to the inverter without pulling up plywood so think we'll wait for a service call
Old 01-24-2021, 10:37 AM   #5
Slidell , Louisiana
The plywood comes up and goes back fairly easily and can save you a trip to the shop. Most models they have an access hatch which if you take up the plywood you should add if you have a jigsaw.
Old 01-24-2021, 11:13 AM   #6
https://photos.app.goo.gl/yLRBjJa26Fdm8w8h7[IMG]
Attached is photo of the access holes,
Old 01-24-2021, 12:19 PM   #7
Slidell , Louisiana
Wow... Where did they put the inverter?
Old 01-24-2021, 01:00 PM   #8
JEB
Lisle , Illinois
Still think it’s worth shutting down the inverter entirely and then cycling the main breaker. Press and hold the power button on the inverter display for at least five seconds until the display goes completely dark. This way you’ll know the inverter is offline instead of in sleep mode. Then cycle the 15A breaker in the WFCO load center. It’s usually the second breaker from the bottom of the panel. If you are on shore power the outlets on the inverter circuit should reset.
Old 01-24-2021, 05:41 PM   #9
We can't find the inverter
Old 01-24-2021, 05:45 PM   #10
Slidell , Louisiana
Turn it on and listen for the fan. On my trailer it is right next to the 12V box in your picture. Did you put a mirror in the hatchways and look around?
Old 01-25-2021, 06:37 AM   #11
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
What is your model? I have a 25A rear bedroom. Mine is located under dinette bench close to fridge. There is an access panel .. open door under bench.. access panel on back wall has 4 screws..
glcmranger is offline   Reply With Quote
Old 01-25-2021, 09:45 AM   #12
Thanks glcmranger. We found the inverter. Got it reset. Thanks everyone for your help. This is the first time we used air forum. Smiles on our faces, on with the adventure
All outlets not working NicheVintage Lights - Interior & Exterior 12 11-19-2020 04:01 PM
Inverter outlets not working attached to shore power kkdesigns Batteries, Univolts, Converters & Inverters 39 02-03-2019 09:16 AM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 10:15 PM
Inverter outlets not working FinnSwede Batteries, Univolts, Converters & Inverters 10 11-16-2011 04:14 PM
