05-20-2023, 11:02 AM
2018 25' Flying Cloud
Portland
, Oregon
Advanced Multiplus: Assisting too soon
I consider myself an advanced Victron user but this one has me stumped.
My Multiplus / Cerbo seems to be interested in showing off and insists upon assisting my AC system before it needs to or it doesn’t draw the full amount from shore that I told it to. I suspect there’s a setting somewhere buried in the menus but I haven’t been able to find it.
The screen attached is one example where the multicontrol is set to 30amps max of shore power (we’re plugged into 30a right now) and is set to “Inverter.” Note that the loads are 3501w, which should be about the max for a 30a system, but it’s only drawing 2945w from the shore and making up the rest from the battery and solar. The question is why? Shouldn’t it draw 30a from shore before tapping the battery?
This is especially a problem when we are running our AC on generator as it will draw the batteries down for no good reason. I have an Easystart and the AC draws less than the generator can provide yet the batteries keep getting slowly depleted.
It seems to start this behavior of under utilizing shore power around 2,500 watts coming from shore.
When the multicontrol is set to “charge only” everything works as you’d expect because the inverter doesn’t try to assist.
05-20-2023, 11:44 AM
Flagstaff
I am a rookie Multiplus user but I will take a shot. Since you are plugged into a 30 amp shore power source only one leg is active on your two leg 50 amp system. So the Multiplus is going into the PowerAssist mode to try to make a 50 amp system. Here is a post were I was trying to figure it out.
Most of my experience is in running a two leg 30 amp shore power connection to the Ford Propower Onboard Generator.
2022 25' GlobeTrotter FB <->2023 Ford F-150 PowerBoost 7.2kW ProPower
Electric Globetrotter
05-20-2023, 12:00 PM
1994 25' Excella
Waukesha
, Wisconsin
Mine did the same thing on my coach. I was told it was because breakers will begin to trip as low as 80% of their rated capacity, especially if a device starts up when near the max load.
The alternative is for the inverter to wait until max is reached, in which case a weak breaker or heavy start up load could create a problem. I left mine to err on the side of caution.
Richard
11018
05-20-2023, 06:31 PM
Portland
, Oregon
In my case I just have single leg 30 amp service, not as fancy as your amazing system.
05-20-2023, 06:34 PM
Portland
, Oregon
Interesting. I suppose I could change the max setting on the multicontrol to allow it to go above 30 and see if that solves it. I was hoping there was some other setting I had overlooked.
05-20-2023, 08:23 PM
1958 26' Overlander
Battle Ground
Knowing your background from following your posts for years, I almost hate to ask. Are you sure the power/loads shown on the screen are accurate? I don't recall which type of batteries you have, but is 13.2 volts at 100%?
05-20-2023, 09:08 PM
Portland
, Oregon
We have 500ah of Battleborn Lithium. I guess I was assuming the Victron display was accurate but thanks for the suggestion. I just checked on the surge protector plugged into the power pole and it claims the same amount of current so I guess I’ll believe the display for now.
So a corollary to this mystery is what’s happening now. We have our Breville electric convection oven running and it turns it’s heating elements on and off like you’d expect to hold a constant temperature, drawing 1,290 watts when on. I have the Victron multicontrol switch set to Inverter just for fun even though the total draw of the trailer is less than half the 30amps I’ve told it to consume if need be.
Now for the weirdness. Whenever the oven pulses on to maintain temperature, the Multiplus assists for a fraction of a second! Sure, this is a first world problem but there is clearly something I don’t understand about when the Multiplus decides to assist. Is it kicking on the inverter whenever it sees a spike in current just to be ready?
05-20-2023, 10:33 PM
Portland
, Oregon
I think I may have found this obscure setting. I can’t mess with it while traveling because I don’t have a MK3 adapter with me but it’s evidently a configuration setting on the Multiplus to allow for slow starting generators set to Econo mode. Here’s what the manual said.
“ 10.1.4. Dynamic current limit
Setting for use with ‘small’ generator - If an inverter-generator is used, such as the HONDA EU series, the shore current setting will be dynamically reduced (following a period of low current consumption) to compensate for the engine reaction time when higher loads are activated.”
This is from this manual https://www.victronenergy.com/media/...-settings.html. 10.1.4
Since I only use my Honda generator when solar isn’t sufficient and then not in Eco mode, I may try turning this off.
It’s not easy to turn on and off as best I can tell unless someone can show me otherwise. I seems to need the Mk3 dongle and a computer with a direct connection to the Multiplus.
05-20-2023, 10:37 PM
1994 25' Excella
Waukesha
, Wisconsin
Good that you found it. Does it really cause any problems when left as it currently is? Yes, you'll momentarily draw down the batteries, but within a few minutes the system should replenish the charge and carry on as normal.
Might be easier to just leave it as is for now and not worry about it.
Richard
11018
05-21-2023, 09:08 AM
2018 27' Flying Cloud
Atlanta
, Georgia
You do not need the MK3 . You can adjust all the settings by connecting through the Victron VRM. You download all the settings to a file using Remote VeConfigure at bottom of Device List. Open the file with the Victron VEConfigure app and save the new adjustments to a file. Then upload the adjusted file back to the Multiplus. You can even do it from home.
05-21-2023, 09:41 AM
Portland
, Oregon
Wow, not that that’s geeky at all! I’ll still have to try that at home since I don’t have a PC with me. That is handier than messing around with the flakey MK3.
I wish Victron would get the Multiplus integrated with Victron Connect!
05-21-2023, 09:45 AM
Portland
, Oregon
In thinking about it I’m not sure that will address the issue I started this thread with of assisting too soon. It will fix the little pulsing behavior. That one isn’t, as you say, a big deal. It’s slightly annoying because, with the Victron under my twin bed, I can hear it turn on and off frequently. I’m more interested to see if that switch has any affect on the too-son-assisting issue.
05-21-2023, 09:48 AM
2019 27' Globetrotter
2023 30' Classic
Denver
, North Carolina
Following
Dave S
05-21-2023, 08:19 PM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
ours
We are new Victron install owners. The unit was professionally installed buy a famous Victron installer. We were shocked after the install to find out no Victron tech support number. Go to your builder?
All I can say is our new system does the same when it plugged in to our storage units 30 amp service with the 30-50 adapter. I thought it was normal? Don’t know
We do not have enough road time to help further.
05-21-2023, 09:19 PM
1994 25' Excella
Waukesha
, Wisconsin
There is a steep learning curve on the Victron systems once you get into the weeds of the menu settings. Fortunately there are some great information pages out there on the Victron Community and other websites.
At one point I did find a tech support number for Victron, but when I checked today was unable to find it again. I remember that it was deeply hidden inside their website.
Richard
11018
05-21-2023, 10:03 PM
Airstream - Other
Airstream - Other
Lady Lake
The rabbit hole
That number or customer concern form takes one down the dangerous rabbit hole of death. if the installer accepts it and figures it’s just a part failure your all good if you word it wrong and they take it as a insult to their build you are a outcast left to fend for yourself. Victron has really dropped the ball with no support.
05-22-2023, 06:38 AM
2022 20' Caravel
2019 Interstate Lounge Ext
Noblesville
, Indiana
went down a rabbit hole with your issue. the MP is rated at 3KVA or 2.4KW maximum continuous output. it would appear you're in excess of this. what is unclear from the documentation from victron is how long assist will be provided when the system is overloaded. so, it would appear the grid is providing 3KW, (i assume, not KVA) and the batteries are providing the remainder, Isn't the MP doing what it should? BTW, I install these and have never placed a load this great, continuously, on an MP, so this is new to me.
05-22-2023, 08:47 AM
2020 25' Flying Cloud
Woodinville
Check your units. 3000VA is about 2400 Watts with a power factor of 0.8 which i think is typical for inductive loads (AC, refer, etc.) So, you might be legitimately getting into assist mode.
My solution is to put the Multiplus II into charger only mode + PassThru via an Victron assistant. If I don't set the PassThru, the MP II tries to charge when the compressor of the AC is off and trips the generation when it comes back up again because the generator cannot respond to the load instantaneously.
Finally, check this thread out. It might help.
https://community.victronenergy.com/...-mutiplus.html
05-22-2023, 09:29 AM
2022 25' Flying Cloud
NCR
, Ontario
inductive loads effect what is seen and the difference between W and VA
with a PF=1, W=VA
as the inductive load % increased, reactive currents causes the W and VA to differ and reduce the effective real load capability
this is a tricky topic for novices and often hard to understand as there is real and imaginary current involved. That is why large machines have a PF rating so that the real power consumption figures can be determined
2023 25' FB FC, hatch, Queen, 30A, 1AC, Awning pkg, Convection uwave.
Multiplus 12/3000-50, 700A Lion, MPPT 100/30, Orion-TR 30, Cerbo GX,GX touch 50, Lynx distributor, dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors
NCR , Ontario, VE3HIU since 1978
WBCCI# 21212
05-22-2023, 04:08 PM
Portland
, Oregon
It may be my misunderstanding of how the Multiplus works. I was assuming that it was passing through all the shore power available to it and only assisting when the demand exceeds the supply. In the case of my screenshot at the beginning of this thread, those are resistive loads (space heater and electric hot water heater.)
Yes, everything works like you’d expect on charge only.
