Following up on this and I think I found the solution.
AFAIK, the power from the Shore Power cable comes up through the back bumper (mounted lower right on the back wall) into a junction box then up to the 120v breaker box.
It appears that after this, the power is then supplied to the trailer and the Converter/Charger pulls it's 120v from the plugin regardless of location and then charges your batteries which feed your
12v system.
This is unfortunate as I would like to configure the AC IN and OUT from the Victron unit (as in the attached diagram).
To perform this function, I will need to run the AC input in the front and then run an AC cable all the way to the back OR place the batteries and Victron in the back and run a DC cable to the front etc.
Am I going about this all wrong?
Any other ideas from the professionals out there??
