Old 10-24-2021, 06:08 PM   #1
1974 Argosy 26
Wilmington , North Carolina
74 argosy inverter issues
What’s happening people out there, I just bought a74 26’ argosy and currently renovating/ restoring, we are keeping a bit of the old but updating a bit as well. My question is about the inverter. It constantly runs and makes a buzzing noise. I’m wondering what I need to do in order to disconnect it, do I need to install some sort of small sub panel? When I bought it the battery cables where live with no battery. I disconnected the both wires from the inverter and now I am getter a short and it actually seems like the whole camper is grounding out or something, I was cutting one of the gas lines to shorten and was shocked and than was locking the battery access and was shocked, one of the fuses blew but still seems to be grounding out… not sure if that the correct term but somehow power is still transferring to either copper or steal around the camper…
Travishunt is offline   Reply With Quote
Old 10-24-2021, 06:55 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Are we talking about an inverter ( a device that turns 12V battery power into 120V AC power)?
-or-
A converter (a device that turns 120V AC into 12V DC to charge the batteries and run 12V stuff when on shore power.) ?
If the battery is out *and* shore power is disconnected, there should be no way to get a shock. If you *are* getting "bit" then one of those two things is not 100% true.
I'm guessing that we're talking about a converter. If it's the original "univolt" that came with the trailer, it's way past it's retirement date. Pull it and replace it.
Old 10-25-2021, 05:30 AM   #3
1974 Argosy 26
Univolt
I think your correct, it a univolt converter. The landline 120v is connected. There is no battery but there were leads going to where the battery was stored, I disconnected the leads since they were still hot. Are you suggesting that I should just scrap the converter and upgrade to new unit?
Old 10-25-2021, 08:14 AM   #4
Kvsterling's Avatar
West Chester , Ohio
Probably a good idea to replace. We did a separate fuse panel and converter/inverter and very happy with function.
Also know that this component also serves as your battery charger, so even though there is no battery…the leads you disconnected are hot
Make sure your batt (+) isn’t touching anything as this would likely give you the condition you are describing (chassis being electrified)!
Kvsterling is offline   Reply With Quote
Old 10-25-2021, 09:19 AM   #5
Half a Rivet Short
2022 Interstate 24X
Hi
Yes, they don't last forever and are known to cause various issues. A replacement is in the $200 range. Get it from somebody you can talk to on the phone. Don't just buy it on Amazon ....
Replacing the converter is a good idea, but likely not the entire solution. There are some checks that need to be done. Getting a pro in to do this is an ok way to go. Not everything is DIY.
Simple tests:
Grab your multimeter and see if the ground lug on the shore power shows continuity to the chassis. If not, fix that.
Now move back to the far end of your shore power cord and do the same check. If it's still connected, that's great. If not ... .fix it.
Next check the ground on your power source. If it's not hooked up, that's a problem.
At this point, the chassis of the trailer should be ok in terms of 120V.
Next up is to check the 12V negative and make sure it is hooked to the chassis. The process is the same.
Once you get the chassis hooked up, you may find beakers popping or fuses blowing. They need to be tracked down and the issue addressed.
Once you replace the converter, the obvious problem may go away even without running through all the checks above. You still need to get the ground fixed. The converter is just showing you that there is a problem there.
Old 10-25-2021, 10:47 AM   #6
1972 31' Sovereign
Dry Branch , Georgia
converter
For my purposes on my converter I disconnected the hot wire to converter and added a light switch to turn converter on and off at will.
You could disconnect your univolt converter then see if you still get shocked.
I would think the shock is from your 120vac system.
Buckless is offline   Reply With Quote
Old 10-25-2021, 11:56 AM   #7
Carrollton , Kentucky
The Univolt that came with my Argosy charged continuously when plugged in, boiling batteries to death. Replaced it with an Intellipower with charge wizard and have replaced 1 battery in 15 years since.
https://www.campingworld.com/progres...E&gclsrc=aw.ds
MichaelS is offline   Reply With Quote
Old 10-25-2021, 05:43 PM   #8
1988 32' Excella
Robbinsville , New Jersey
Some Airstreams and Argosy's from around that year had a reverse polarity light. This light is a SAFETY HAZARD since when you plug in to an outlet that has a reversed polarity the power going through the light will electrify the shell.
Old 10-25-2021, 06:56 PM   #9
1976 24' Argosy 24
1999 30' Excella 1000
White Haven , Pennsylvania
What he said. I did a 60watt? version for our Argosy
Gkiesel is offline   Reply With Quote
Old 10-26-2021, 02:28 PM   #10
1988 32' Excella
I guess you meant 60amp version.
60watt = 5amp which isn't much.
Old 10-26-2021, 04:33 PM   #11
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Most likely 60 amp...
Richard
Old 10-26-2021, 06:57 PM   #12
1976 24' Argosy 24
Yes. Thank you so much for correcting that.
Old 10-28-2021, 04:08 PM   #13
Eric 26 Argo's Avatar
Airstream - Other
Knoxville , TN
If you are getting a shock form the body of the camper STOP EVERYTHING and unplug the shore power. You need to find the short in the electrical system. It's likely that the rodents have chewed on one of the 120 volt wires and exposed the hot wire.
Congratulations you now get to remove all the skins and see the rodent infested insulation.
Eric 26 Argo is offline   Reply With Quote
Inverter Issues? time2travel Batteries, Univolts, Converters & Inverters 1 02-03-2021 09:31 PM
2020 AS Inverter / Battery Issues-HELP! jjohnson2033 Batteries, Univolts, Converters & Inverters 14 07-12-2020 09:03 AM
Generator / Inverter Issues SWH Sprinter and B-van Forum 32 07-17-2019 09:48 AM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 02:48 PM
Solar Panel and Inverter Issues on 19ft Bambi campadk Generators & Solar Power 10 10-28-2006 10:59 AM
