12-29-2020, 09:42 AM
2018 25' Flying Cloud
Mission
6V vs AGM
What are +/- of replacing original 12V Interstates?
2018 25' RB Flyingcloud
12-29-2020, 09:48 AM
Oswego
IMO, there are pluses to either, and no minuses.
-Rich-
12-29-2020, 09:57 AM
2019 27' International
Western NC
, North Carolina
Only variable is ahr capacity. Which will better meet your needs?. Plus to AGM is no maintenance.
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
12-29-2020, 10:05 AM
Oswego
There are some other physical factors. Available physical dimensions vs. Space constraints. Inside vs. Outside placements. Maximizing Ah capacity, given those considerations. Necessary charger/controller changes?
-Rich-
12-29-2020, 10:09 AM
2002 25' Safari
Dewey
Because the 6 volt (golf cart) batteries are taller you can get more amp hours in a smaller footprint.
Richard
12-29-2020, 11:05 AM
2007 27' International CCD FB
San Diego
Both are notable battery types that would be a great upgrade. Both a highly durable, long life, deeper discharge capabilities over standard batts.
AGM
Pros
- no need to water
- higher charge and discharge rates (to run higher wattage inverters)
Cons
- cost
- if abused or accidentally damaged with deep discharge in storage, cost to replace
6V FLA
Pros
- Cost
- Easy to source
Cons
- Have to water couple times a year
12-29-2020, 11:10 AM
Oswego
Weight vs. Ah capacity gives AGMs a nod over flooded.....if that is a concern.
-Rich-
12-30-2020, 07:47 AM
Mission
Thanks all for your responses. If I go with 6V, I'll need to modify the battery box, right?
12-30-2020, 07:53 AM
2002 25' Safari
Dewey
Vinnie's North Bay used to have a drop in adapter to expand the battery box. You might want to check with him.
http://www.vinniesairstream.com/
Richard
12-30-2020, 08:33 AM
1964 22' Safari
modesto
First of all If you are considering 6V batteries (more amp hrs.) I can highly recommend Lifeline AGM deep cycle batteries. Mine have been in service since 2013 and still strong.
https://lifelinebatteries.com/produc...eries/gpl-6ct/
-Dennis
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Battery AGM (4) 6V GC2 vs (2) AGM 8D
Torpedo Family |
Land Yacht/Legacy Motorhomes |
3 |
11-15-2012 05:35 PM |
New Progressive Dynamics convertor, AGM battery, and Pendant questions
wacnstac |
Batteries, Univolts, Converters & Inverters |
16 |
05-09-2007 09:12 PM |
Cabelas AGM batteries
wacnstac |
26 |
10-13-2006 07:22 AM |
AGM battery question
LuminumTraila |
3 |
03-01-2005 04:56 AM |
Charging AGM trailer batteries from vehicle
mswartz |
5 |
05-15-2004 02:34 PM |
