Old 09-25-2017, 01:44 PM   #1
2016 23' Flying Cloud
Fanwood , New Jersey
6V GC batteries for 2016 FC23D
I measured the size of the battery bank of our 2016 FC23D, and it is roughly 12" x 15" x 12" (depth).
So it appears that I can put two 6V batteries, like these:
http://www.trojanbattery.com/pdf/dat...ata_Sheets.pdf
http://www.trojanbattery.com/pdf/T10...t_DS_Final.pdf
Has anyone had a success story with these batteries?
Atsushi
Atsushi is offline   Reply With Quote
Old 09-26-2017, 06:55 AM   #2
https://www.dropbox.com/s/opd9je0j1p...rsion.jpg?dl=0
I'm wondering if this is how to convert 2 12V battery system (parallel) to 2 6V battery system (serial).
Is my understanding correct?
Thanks!
Atsushi
Old 09-26-2017, 11:08 AM   #3
I think I figured out how to post an image.
Is this a correct way to run wires for 6V set up?
Name:	battery conversion.jpg
Old 09-26-2017, 11:26 AM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Why do this? At best you are getting a 10% boost in capacity compared to other options.
Of the bunch, the Trojan T-105's are the only ones worth bothering with. You want to be sure you have their brand name and model. A "Uncle Bob" T-105 is not the same thing ... The AGM's give you no advantage over 12V AGM's from several other outfits.
Old 09-26-2017, 11:34 AM   #5
2007 22' International CCD
As an engineer, I find that 6-volt batteries in series are more predictable in charge and discharge behavior than paralleled 12 volt batteries.
Nasty thing happen when one cell in a set of parallel batteries fails--the other battery tries to pull up the dead cell, dumps tons of current into it, and fries both batteries...not a pretty scene. Things get hot, cells spew acid vapor, and you get a hazardous situation in a hurry...
Yes, series batteries have their issues, but the failures tend to be self-limiting--a dead cell just drops the voltage of the set, and may not draw excess current from anything but the battery charger.
I have a slightly larger battery box with two CG-2 batteries in series, and monitor the voltage at the center point of the string to see if anything untoward is going on...except for the crappy OEM battery charger (its going away soon) this works fine for my needs, and the solar keeps them charged in storage...
rmkrum is online now   Reply With Quote
Old 09-26-2017, 11:45 AM   #6
dmbecke's Avatar
2014 25' FB Flying Cloud
Des Peres , Missouri
6 V batteries are usually too tall for the box
I put two group 31 batteries in and got similar amp hrs as the 6 v
dmbecke is offline   Reply With Quote
Old 09-27-2017, 08:47 AM   #7
Half a Rivet Short
Hi
A shorted cell will kill you if it's in a series connection or in a parallel setup. There's no magic there. In both cases the converter / charger will boil the battery with the short. If you catch it right away you *might* save the second 12V battery. You are unlikely to save the second 6V. In both cases the batteries will be replaced together so no big deal. The subtle issue is that charging is by far the most likely time to short a cell .
If you want to keep 6V in series properly equalized, you should do a balancer (just like on a lithium stack). With a 12V parallel you would do a current balance. Nobody ever does either one so again, not much of a difference.
My main point is that people seem to rush out and "go 6V" like it's some sort of magic answer. It's very much not a magic answer. It's a "maybe 10%" sort of thing at best. Battery capacity is also a "maybe 10%" sort of thing. Some will do 120% of ratings. Others struggle to get to 90% of what's on the label. There are other things that one could put the same effort (and money) into to get a 10% here or there.
No this is not the only area that people to wild pulling out batteries and re-configuring things. The guys with big boats make RV people look pretty tame in this regard. I've been through enough of those very major re-do's to have seen the results. Lots of effort for very modest gain is the normal outcome.
Old 09-27-2017, 10:00 AM   #8
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Looks good to me. I say go for it. I am only one data point, but I installed 2 6v golf cart batteries 7 years ago and they are doing fine. We typically boondock and camp 3-4 days. The voltage typically never drops below 12.6 ,no load, after 3-4 days. We carry a 1,000 watt Honda but it is only an insurance policy in case something weird happens.
Dan
2016 FC23D tire questions (pretty basic) Atsushi Tires 19 09-14-2017 07:31 AM
2016 FC23D heating pads for tanks? Atsushi 2016 - Current Classic (all lengths) 1 06-26-2017 09:08 AM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
