Old 10-21-2021, 03:56 PM   #1
2003 22' International
Bokeelia , Florida
50 amp - 30 amp
I have an 2003 International. The park Iím In didnít have a 30 amp receptacle so I put an adapter and plugged into the 50 amp service plug. Would this effect the cost of electricity?
Walkabout6 is offline   Reply With Quote
Old 10-21-2021, 04:03 PM   #2
ITSNO60's Avatar
Tucson , AZ
No. Some will argue that an unbalanced load will cost you more but that does not apply to 120/240 volt residential service. Besides that you are still taking power from only 1 leg whether plugged into a 30 or a 50 so it's moot anyway.
Brian
ITSNO60 is offline   Reply With Quote
Old 10-21-2021, 04:44 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
If you do the 50 to 30 amp connector do you get 30 amps or 25 amps?
Old 10-21-2021, 04:50 PM   #4
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
50A service is 50A at 240V. Each of the two legs is a 50A 120V leg. If you could, your adapter would get you 50A instead of 30A.
Old 10-21-2021, 05:04 PM   #5
1988 25' Excella
1987 32' Excella
I knew better. I just must have been asleep when I posted that question.
Old 10-22-2021, 11:41 AM   #6
DaveG's Avatar
Here and There , Pacific Northwest
Compare the electrical to your water hose. Amps is quantity (in this case available), Voltage is pressure. The 50 amp rating is overcurrent protection, your circuit breaker. The circuit breaker is the gate keeper. It is best to match your load to the rating of the wiring, like 30 amp or 50 amp. It is okay if you use a 30 amp cable on the 50 amp service because at your RV the circuits have breakers. If you try to draw more than the 50 amp quantity all at once the 50 amp rated circuit breaker will trip. If you connect to high voltage there is too much pressure and it bursts your electrical stuff (lets the *smoke out). Watts is the way your consumption is measured so cost is based on what you consumed (electrical energy converted to work).
(*smoke is what makes all of your electrical stuff work. If you let the smoke out your stuff will stop working)
DaveG is offline   Reply With Quote
Old 10-22-2021, 08:54 PM   #7
2019 22' Sport
Waynesville , Missouri
DaveG- And you can never put the smoke back in. Have to get a new one.
DAVSCH is offline   Reply With Quote
1973 & 1976 Windows Parts & 80's Door-Negotiable tbashin Airstream Classifieds 0 01-01-2018 09:22 PM
Carefree Roadside & Rear Window Awning Arms & Rollers For 1976 31' Airstream Sovereign mrnos44 Airstream Classifieds 0 08-23-2016 08:08 PM
Goucho couch,original am/fm 8 track & lots of wood & aluminum from interior remodel gquailhunter Airstream Classifieds 0 09-19-2015 05:25 PM
