Old 04-02-2024, 01:24 PM   #1
Dennawayne
Dennawayne's Avatar
2021 22' Caravel
Clarkdale , Arizona
30 amp Fuse why so big??
I have a 22’ 2022 Caravel that has had lithium batteries put in. Of course the AGM’s are gone the original wiring for the tongue jack is still intact. My question is why such an enormous 30 amp blade fuse? The side from the jack is 10 awg and other is battery cable.
Thanks from puzzled.
Dennawayne is offline   Reply With Quote
Old 04-02-2024, 01:48 PM   #2
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
It's a Maxi fuse and they are commonly used on heavy inrush applications like motors, instead of fusible links. The reason is because they have more time delay than a normal ATC or ATO blade fuse. When starting a heavily loaded motor there is a high inrush current and the Maxi fuse will hold up to that.
Brian
ITSNO60 is offline   Reply With Quote
Old 04-02-2024, 04:55 PM   #3
Dennawayne
Dennawayne's Avatar
2021 22' Caravel
Clarkdale , Arizona
Thanks Brian so 10 awg should be good yes?
Old 04-02-2024, 05:27 PM   #4
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
10 AWG is perfect for that short distance.
Brian
Fuse remover, fuse set, light Vitaver Electrical - Systems, Generators, Batteries & Solar 1 10-30-2022 01:04 PM
Why the big payload difference between 3/4 & 1 ton Wanna EB Tow Vehicles 29 04-25-2016 08:37 AM
Big storm = Big dent TennisMan 2007 Safari SE 10 07-17-2007 09:20 AM
BIG BIG AIR HUG!!! & "eh" Streamin' THANKS 05ModPod Our Community 6 01-30-2004 07:50 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
