Old 11-03-2019, 12:22 PM   #1
1975 31' Sovereign
brewster , New York
24volt tender?
I have a autocraft deep cycle marine 24 DC-1 battery for my trailer,is it ok to use a 12volt charger or tender over the winter to maintain the battery while it is in my garage?
blumob is offline   Reply With Quote
Old 11-03-2019, 12:41 PM   #2
Registered User
2016 25' Flying Cloud
Fairfield , California
Just wanting to make sure I an understanding you correctly, 12 volt battery tender not a 24volt tender.
Yes, it is fine to use one as long as it is of the same voltage and that the tender goes in to a float mode to keep from boiling your batteries by switching to a very low amperage and the correct float voltage input.
One can not pump 14.5volts and 10amps continuously into a battery without damaging it.
Matti
Mattirs is offline   Reply With Quote
Old 11-03-2019, 12:56 PM   #3
1975 31' Sovereign
brewster , New York
I believe it is a 24volt battery,so I guess I need a 24volt tender?
Old 11-03-2019, 01:04 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It might be a group 24 which is the physical size of the battery, but the DC voltage of Airstream trailers is 12 volts.
Richard
Old 11-03-2019, 05:26 PM   #5
Registered User
Agree, type 24 size, they are standard on an Airstream; 12volt battery, again standard.
Are the batteries Interstate?
Alot of battery tenders are 12 or 24 volt abd will automatically select the correct voltage.
Old 11-03-2019, 05:39 PM   #6
1975 31' Sovereign
brewster , New York
Thank you everyone. Now I understand 24 is the group size and it is a 12 volt battery. Just went down to garage and attached 12 volt battery tender. After all these years still learning about my Airstream with your help.
Looking for a battery tender russingr Batteries, Univolts, Converters & Inverters 8 04-05-2013 06:20 PM
Battery Tender and Univolt? AldeanFan Batteries, Univolts, Converters & Inverters 8 08-31-2011 11:16 AM
Battery Tender Hookup for two parallel batteries Tater Batteries, Univolts, Converters & Inverters 0 11-29-2010 04:28 PM
Deltran Battery Tender Gene Wissink Batteries, Univolts, Converters & Inverters 0 10-13-2010 05:57 PM
