04-30-2021, 11:11 AM
2002 19' Bambi
1989 29' Excella
1980 28' International
Avon
12Volt Recommendations: Non-Boondocking
I assume a deep cycle AGM is the way to go. My situation: the trailer lives outside, stationary, and is plugged into shore power 100% of the time. I don't want to transport the battery home to store indoors in the winters (I'm only there 3 weeks at a time, twice a year). It does get a bit cold (SE Utah, down to maybe 0 degrees)...I'm interested in the lowest cost per year, given my circumstances.
PS: I've been running a timer for the shore power, set for on one hour a day while I'm away, but may invest in a battery minder in the future.
04-30-2021, 05:12 PM
1986 31' Sovereign
Miami
From what you have described, I would buy the least expensive AGM deep cycle battery you can find. Costco? Sams?
I dont know what converter you have. If it is a three-stage, you are good to go. If not, a battery tender would be in order.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
04-30-2021, 05:20 PM
2017 30' International
Broomfield
Agreed. I would put the battery on its own battery minder 24/7.
04-30-2021, 06:58 PM
2002 19' Bambi
1989 29' Excella
Avon
Coscto AGM deep cycle and a battery minder it will be...Thanks
04-30-2021, 06:59 PM
Baltimore
, Maryland
If the trailer never moves and you have shore power, do you need a battery?
Cheers, John
04-30-2021, 07:06 PM
2002 19' Bambi
1989 29' Excella
Avon
Cheers, John
Oh yes, without a battery NOTHING works (not even 110 outlets). At least that's what happened when I pulled the dead battery.
05-01-2021, 12:12 AM
2009 19' Flying Cloud
San Mateo
That doesn't sound right (for most AS)? Is your AS wired so that all of the outlets are connected to an inverter and it doesn't have a shore power passthrough or something?
For most AS, even if you don't have a battery connected (or it's dead), if you are connected to shore power, the 110v outlets should work, isn't it?
05-01-2021, 07:24 AM
2019 30' Flying Cloud
Grass Lake
, Michigan
If cost is your primary objective, why not go with a single flooded deep cycle battery? Much cheaper purchase price than AGM.
Your 110 outlets should still work w/o a battery installed, as should your 12v stuff (assuming the converter is working properly).
05-01-2021, 07:28 AM
2004 28' Classic
Monument
An advantage of the AGMs, you do not need to maintain the water level in the battery.
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
