I could use a little help. I am camping right now and the GFCI keeps blowing. I have narrowed it down to the intelipower 9270. But I am not sure why. Is the intelipower bad? I took out all the fuses leading out of the intelipower so I know it is not the
12 volt system causing the isssue. I am getting the extra juice out if the intelipower so I think it is working right. The breaker does not blow when the intelipower is unplugged. The time it takes for the breaker to blow with it plugged in changes from instantly to 30-40 minutes with the intelipower plugged in.
I am at a campground hit bad by huricane Irene so could it be the shorepower causing this?
I started to think it was the 32 year old gfci breaker that went bad. I bought a replacment (still have an hours drive to get back to try) but still not sure what else it can be. I think the grounds are good because it has been working fine for the past 3 years.
Any thoughts would be greatly appreciated.
