Old 03-08-2021, 09:16 PM   #1
2013 27' Flying Cloud
Calgary , Alberta
12/3000 Victron Multiplus AC in and out wiring
Hello,
Would like your opinion/advice on wire gauge for my 120v AC in and out connections to my Victron Multiplus 3000. I have a 30amp 2013 27FB and I am in the process of installing the inverter under the bed.
It looks like the rough length of wire required to go from the inverter to the AC distribution panel would be 25 ft. I was planning to use 6 AWG but I think for 30 amp I should be okay with 8 AWG. By using 8 vs 6 I am saving space and can use a smaller conduit along the bedroom wall.
For those of you with a Multiplus 3K what did you use?
Peter
Peter C is offline   Reply With Quote
Old 03-08-2021, 10:43 PM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
I used 6 awg for both the inverter (Victron Multiplus 3000) to AC panel and shore power to inverter. My total run for both was less than 20'. Keep in mind your shore power is routed to the Inverter also so you might want to look at voltage drop for both runs.
Here's a simple online calculator to give you an idea of what the voltage drop is.
https://www.calculator.net/voltage-d...s=30&x=64&y=24
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 03-08-2021, 11:02 PM   #3
Paradise , Texas
57 vintage, using your calculator, 10ga romex is adequate. Result is still much less than the 3% drop many code books require...
Crackerman is offline   Reply With Quote
Old 03-09-2021, 08:04 AM   #4
57Vintage's Avatar
1958 26' Overlander
Images: 22
That's true. My goal was to minimize voltage drop, not meet a code acceptable limit.
Harold & Rebecca
Our thread:
Old 03-09-2021, 08:20 AM   #5
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Your 30Amp unit will be fine with 10awg for the input and output of your MultiPlus 3000.
Voltage drop is not an issue on your length runs.
Old 03-09-2021, 10:11 AM   #6
Calgary , Alberta
Thanks guys I appreciate the advice.
I am a bit concerned with the shore power to inverter. Considering the 25ft cord to the pedestal, plus from the plug to the transfer switch behind the AC distribution panel, and then the 25 foot run to the Multiplus. This might need 8 AWG.
Now my next issue is the fact that I cant find 8/2 or 10/2 NM-B wire at the Canadian distributors. They only seem to stock 8/3 and 10/3. I might go with single 8 AWG and run 6 wires (3 each way). I can easily buy it in red, black, green, and white.
I can order 10/2 and 8/2 from US but it is pricey and wont get here for 10 days. I am hoping to run the wire this weekend.
-Peter
Victron MultiPlus 3000 overheating SeaLevel Generators & Solar Power 28 03-30-2020 12:22 AM
Idle draw of Multiplus 2000 and Multiplus 3000 Dave-n-Janet Generators & Solar Power 10 11-24-2019 06:04 AM
Victron Multiplus Hybrid/Boosting Inverter/Charger Install CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 7 03-15-2016 11:03 PM
