Old 11-13-2017, 03:14 AM   #1
2018 27' Flying Cloud
Zamp vs. Battery Tender
I have a 15W Battery Tender solar panel that I used on our 23D to keep the batteries topped up. We just this weekend picked up our 27FB, it comes prewired with the Zamp solar connector (same as what Battery Tender uses). Anybody here use something other than the Zamp panel to maintain their batteries? As long as the wiring is correct, I don't see an issue (I do have to check that. I've read that Zamp wires things differently than other solar manufacturers).
-Wayne
wbrisett is offline   Reply With Quote
Old 11-13-2017, 02:03 PM   #2
rperrym's Avatar
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village , Arkansas
I was wondering which Battery Tender model comes with Zamp solar connectors? The ones I have seen just have alligator clips.
Rick
2017 27 Tommy Bahama
2020 2500 GMC Duramax
rperrym is offline   Reply With Quote
Old 11-13-2017, 03:19 PM   #3
2015 30' Classic
Pleasanton , California
The Zamp solar connector is wired directly to the battery, so you can plug your Battery Tender in safely.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 11-13-2017, 04:03 PM   #4
2017 25' Flying Cloud
Raleigh , NC
Zamp connectors are standard SAE connectors, but they wire them the opposite of normal. In order for it to work with other brands, you have to reverse the wires at the battery. Move the wire connected to negative to the positive pole and positive to negative. I use my Renogy 200 watt solar panel that way and it works just fine.
JoeHTP is offline   Reply With Quote
Old 11-13-2017, 04:24 PM   #5
I have read that about the Zamp which is why I asked. I bought one of the 15W Battery Tender solar panels and it has the same connector, so I'll change the cabling. Thanks!
I'm excited... We'll take the 27FB out for the first time on Sunday. We haven't told the folks we're camping with. We're going to see how long it takes them to realize that we're in a different Airstream.
Old 11-13-2017, 04:27 PM   #6
Rick
http://www.adventurerv.net/battery-t...source=Froogle
If you look at the enlarged photo on this site, you'll see the same connector. you can use the clips if you want, but you have to plug those into the connector.
Old 11-13-2017, 06:52 PM   #7
rperrym's Avatar
Thanks for the information. I misunderstood the original poster's comment. I thought we were talking about the connections on a 110 volt Battery Tender battery charger that would connect to the Zamp connection on my Airstream. Wasn't thinking about a Battery Tender solar charger.
Rick
Old 11-14-2017, 08:11 PM   #8
Raleigh , NC
In addition to the Renogy Solar panel, I also have a Battery Minder that has an SAE plug. Once I reversed the Zamp cables, I plug it into the Zamp connector to maintain the batteries.
Looking for a battery tender russingr Batteries, Univolts, Converters & Inverters 8 04-05-2013 06:20 PM
Battery Tender and Univolt? AldeanFan Batteries, Univolts, Converters & Inverters 8 08-31-2011 11:16 AM
Battery Tender Hookup for two parallel batteries Tater Batteries, Univolts, Converters & Inverters 0 11-29-2010 04:28 PM
Deltran Battery Tender Gene Wissink Batteries, Univolts, Converters & Inverters 0 10-13-2010 05:57 PM
