Old 09-02-2021, 09:24 AM   #1
2021 23' International
P , California
Zamp Rooftop Panel Gone With The Wind
Six months ago I installed a 170watt rooftop solar panel on my 2021 23FB using the supplied red 3M adhesive tape. Despite me doubting the tape would hold, the dealer insisted that "you could tow a truck using this tape." And that "this is the standard practice."
Everything has gone well for a few thousand miles in all kinds of weather...until hitting a crosswind in South Dakota. I didn't even notice until checking the Victron solar panel app that afternoon to discover no current flowing.
Sure enough when inspecting the roof, the Zamp panel had blown off completely...leaving behind a few dents in the roof. Now traveling east in northern Minnesota heading for New England. Guessing that roof panel repair and panel replacement will be expensive so I'm wondering if Geico would cover the repair.
Any thoughts?
Name:	zamp panel.jpg
ID:	403251   Click image for larger version
Name:	zamp damage.jpg
The adventure begins when things stop going as planned.
https://youtu.be/Y3Gqm6__860
viking1 is offline   Reply With Quote
Old 09-02-2021, 09:49 AM   #2
2018 30' Classic
Williamsburg , VA
Mine are drilled into the roof, I'm surprised the recommended tape.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is offline   Reply With Quote
Old 09-02-2021, 10:12 AM   #3
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
That panel was improperly installed. When using 3M VHB tape one must also use Sikaflex 221 to help adhere the panel and protect the Sikaflex from the weather and elements.
Old 09-02-2021, 10:22 AM   #4
P , California
Thanks. You are probably correct. I wish the dealer had advised me of that.
(still not sure of what you said though...how does Sikaflex protect Sikaflex?)
Old 09-02-2021, 10:23 AM   #5
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
You will need to check with your insurance company about coverage, but yes, panel replacement is expensive. And they can not be replaced by just anyone. Do your research on this beforehand. Even most AS dealers do not do a good job of panel replacement.
thewarden is offline   Reply With Quote
Old 09-02-2021, 10:24 AM   #6
P , California
I was surprised also at the recommendation of tape to secure the panel feet. But I am also reluctant to drill holes in the roof.
Old 09-02-2021, 10:24 AM   #7
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
In the first photo there appear to be two brackets alongside the solar panel with screws through them. Were they also holding the panel or do they have another function?
Richard
11018
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is online now   Reply With Quote
Old 09-02-2021, 10:26 AM   #8
P , California
No screws were used at all--only the red 3M tape supplied by dealer.
Old 09-02-2021, 10:28 AM   #9
ShawnSk's Avatar
2021 20' Bambi
FREDERICKSBURG , VA
It seems like everyone is recommending tape only for these installs to the point that people were getting angry at me for recommending screws. This is what I did and haven't had any issues in case you are going to install solar again.
Get some of these mounts https://www.amazon.com/Renogy-Solar-.../dp/B0751T3QV6
They are nice because you can seperate the mount in two instead of trying to get to the screws on the underside of the panel. I did use 3M tape to mount it once everthing was lined up. Do your pilot holes for your screws. I used metal roofing screws since the have a nice rubber washer. 2 screws each leg, coat the mounting bases with Sikaflex. Once it dry mount the panel to the brakets and your good to go, then you get screws and tape. Havent had any leaking issues
ShawnSk is offline   Reply With Quote
Old 09-02-2021, 10:32 AM   #10
waninae39's Avatar
2017 22' Sport
NCR , Ontario
improper installation and use of 3m VHB!
the tape alone is not the soln. you need sufficient tape to hold the load.
as well when using 3M VHB tape, please use Sikaflex 221 tape over the 3M and the bracket mounts.
This ensures the the panel mount is protected from any weather and elements.
waninae39 is offline   Reply With Quote
Old 09-02-2021, 10:46 AM   #11
P , California
My first thoughts when discovering this issue was what a disaster this would have been if the panel blew off and went into the windshield of a following vehicle.
Old 09-02-2021, 10:49 AM   #12
P , California
My concern with using screws is that I'd need to drill into a rib as the aluminum panels are not thick enough to hold much. How to hit that target?
Old 09-02-2021, 11:37 AM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
[QUOTE=viking1;2533525]Thanks. You are probably correct. I wish the dealer had advised me of that.
(still not sure of what you said though...how does Sikaflex protect Sikaflex?)[/QUOT
Our roof has a few rivets in it...none of ours are leaking.
If I were, but I wouldn't, put a solar panel on the roof.
I would drill a few more holes, enough to use more and ro-buster mounting hardware, forgo the 3m tape and use 3m 5200.
Good Luck....
Tahawus
Love for the Adirondacks
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire.
RLC
Old 09-02-2021, 12:15 PM   #14
Flagstaff , Arizona
I always use 3M adhesion promoter for these roof top applications. Then cover installation with Sikaflex.
2021 F-150 PowerBoost/7.5kw ProPower =+= 2022 GlobeTrotter 25FB Twin All Electric
goldenchase is offline   Reply With Quote
Old 09-02-2021, 12:46 PM   #15
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Backing up a bit:
Make *very* sure the surface is clean before you do much of anything. Wax or other coatings make for a shiny trailer and a *terrible* bond. Some recommend hitting the surface with a light pass of fine grit sand paper to "really get there". I'm not 100% convinced you have to go that crazy.
How do I know the tape has issues with wax and things like that? I use it on a lot of things. Sometimes they fall off .....
Old 09-02-2021, 01:29 PM   #16
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
I wince at using tape only... not reliable enough for me.
Airstream of Santa Barbara did a good job installing a Zamp panel on mine. It IS screwed on roof. I feel better knowing that the solar will always be on roof even with winds, oh yea, normal wind, but not like F5 Tornado.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Old 09-02-2021, 11:33 PM   #17
P , California
So the function of using Sikaflex tape is keep the bonding agent in the 3M tape from drying out?
Old 09-03-2021, 12:06 AM   #18
2015 25' Flying Cloud
Schaumburg , Illinois
Sikaflex is like caulk in this application ... or maybe I should say thats how I used Sikaflex on my install. You need to surround the entire perimeter of whatever bracket(s) has the 3M tape as the bonding method, and the Sikaflex acts as a barrier to keep any moisture from getting under the bonded surfaces, preventing a loss of adhesion. The Sikaflex "seal" around the perimeter of the bracket must be 100% coverage of the gaps, it cannot be partial, if there is any segment, even a small segment, where water can penetrate, you risk losing the bond.
I have 5 solar panels on my roof (3 are a year old, 2 more are only about 4 months old), but I check the secureness of the 3M points every now and then, so far zero problems, and I have zero concerns about them. Sikaflex is a critical part though ... it protects the underlying "glue" from degradation (if my comprehension of the whole approach is correct). As someone else also mentioned, clean surfaces at the start, before 3M tape application, is also critical.
1StreamDream is offline   Reply With Quote
Old 09-03-2021, 12:39 AM   #19
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
This is how the professional installation of my roof panels was done. Not only did my installer assure me that they had had zero problems over many years with this method but that it was very secure and preferable to creating holes in the roof.
Mike
2020 25' Globetrotter Twin | 2017 F250 4x4 6.7 max tow Platinum
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
mikeinca is offline   Reply With Quote
Old 09-03-2021, 12:43 AM   #20
Glen Carter's Avatar
2018 19' Tommy Bahama
Rancho Santa Margarita , CA
I question the "red" 3M tape. The 3M VHB I have has a white peel off with red lettering?
Glen Carter is offline   Reply With Quote
zamp rooftop 3 port install 1StreamDream Generators & Solar Power 5 10-07-2020 12:52 PM
Zamp 90W Rooftop Bracket Feet Install smsasf Generators & Solar Power 1 08-18-2020 07:44 PM
Possible to re-wire the Zamp rooftop combiner? Kalashnikov Generators & Solar Power 21 03-18-2020 10:13 AM
My beautiful Airstream is gone, gone, gone. mhilley On The Road... 55 02-12-2012 11:44 AM
That page peal is gone! IT's GONE! GONE! YES!! AIR-Quarius Off Topic Forum 2 10-11-2010 03:18 PM
