Old 01-30-2019, 12:19 PM   #1
SilverWind's Avatar
2022 20' Basecamp
1968 17' Caravel
Los Osos , California
ZAMP Portable Panel Connected to AS via the 7way TV Cable?
Has anyone here found an appropriate 7way to ZAMP portable solar panel adapter to feed the charge to their Airstream via the tow vehicle umbilical cable?
SilverWind is offline   Reply With Quote
Old 01-30-2019, 12:31 PM   #2
"Cloudsplitter"
Welcome Aboard!! 🥂👍
Yes...that's how I've been doing it for years..🤓
Purchase a 7way female plug and wire the Zamp into the charge wire. 👍
NOTE
The end connector on this plug is for a previous set-up.
ID:	332632   Click image for larger version
I’m an AS owner, and I'm really good at fixing things that aren't broken.
Old 01-30-2019, 12:33 PM   #3
1955 22' Safari
Laredo , Texas
Amazon
https://www.amazon.com/dp/B00FYUCQXK...v_ov_lig_dp_it
55AS is offline   Reply With Quote
Old 01-30-2019, 03:10 PM   #4
SilverWind's Avatar
2022 20' Basecamp
1968 17' Caravel
Originally Posted by BambiTex View Post
I bought these from the Airstream Life Store thinking that they would work with my ZAMP 140 portable panel. The ZAMP controller gives a 602 error code which normally means reverse polarity. I tried the setup on both my 2017 25FB and our 68 Caravel. Apparently they were made for the GoPower portable panels that Airstream Life sells and are not wired correctly for the ZAMP.
https://store.airstreamlife.com/coll...-7-way-adapter
https://store.airstreamlife.com/coll...olar-panel-kit
Old 01-30-2019, 03:11 PM   #5
SilverWind's Avatar
2022 20' Basecamp
1968 17' Caravel
NOTE
Hi Bob....how can I tell which is the charge wire?
Old 01-30-2019, 03:22 PM   #6
"Cloudsplitter"
Originally Posted by SilverWind View Post
I bought these from the Airstream Life Store thinking that they would work with my ZAMP 140 portable panel. The ZAMP controller gives a 602 error code which normally means reverse polarity. I tried the setup on both my 2017 25FB and our 68 Caravel. Apparently they were made for the GoPower portable panels that Airstream Life sells and are not wired correctly for the ZAMP.]
I've never had a problem...I just wire the pos from the Zamp to the pos on the connector.
It's best to confirm pos with a test light on the male plug....pos charge from the Zamp goes directly to the AS batteries...same as if it was the charge wire from the TV...one wire.
ID:	332646   Click image for larger version
Old 01-30-2019, 03:42 PM   #7
SilverWind's Avatar
2022 20' Basecamp
1968 17' Caravel
Thanks Bob. I'll give it a try.
Old 01-31-2019, 06:25 AM   #8
Kensington , Maryland
Bob for supreme leader. Portable panels are on my list, this makes it easier.
2018 28' RBT International Serenity
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 01-31-2019, 07:37 AM   #9
"Cloudsplitter"
I be letric, challenged, if I got thru it anyone can.
I understand now that Zamp does wire the SAE connectors differently...was ignorant of that fact just and did what I normally do... used my test light to confirm polarity.
Old 01-31-2019, 09:20 AM   #10
Life is a Highway's Avatar
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake , Florida
We were told no 7 pin adaptation from Zamp. Go Solar has them for their system
If your clever you could follow the wiring schematics make up a connector
Life is a Highway is offline   Reply With Quote
Old 01-31-2019, 09:28 AM   #11
"Cloudsplitter"
If your clever you could follow the wiring schematics make up a connector using a 7 pin to 4 pin adapter
What are I missing?
I only needed a 7pin female into two pin SAE into the two pin Zamp SAE.
Old 01-31-2019, 01:10 PM   #12
SilverWind's Avatar
2022 20' Basecamp
1968 17' Caravel
From what I understand.....ZAMP reverses the male and female SAE connectors in order to protect the otherwise protruding male. In other words the male becomes the recessed female and polarity is reversed.
I ordered a set of polarity reverse adapter connectors so that I can use the GoPower 7pin adapter setup.
And a second type, just in case.
Make sure that what you order is rated at a high enough amperage for your particular panel.
Old 01-31-2019, 02:08 PM   #13
"Cloudsplitter"
Thanks...that makes it easier for sure.
I was not aware of the Zamp reversal...I just did what my test light said.
A lot like breakfast...You can't go rong if you do exactly what you're Rice Krispies tell you. 🤔
Old 01-31-2019, 02:29 PM   #14
2007 22' International CCD
A lot like breakfast...You can't go rong if you do exactly what you're Rice Krispies tell you. ��
I just listen to the voices in my head--they have more interesting ideas...than Rice Krispies do...
Too bad nobody sells the "Chocolate frosted sugar bombs" from the Calvin and Hobbs comic strip...
Old 01-31-2019, 03:04 PM   #15
"Cloudsplitter"
Old Farts Unite...
Rich,
After posting I had to make sure Snap, Crackle and Pop were still viable.
Bosco, Postum anyone?😂
Old 01-31-2019, 03:27 PM   #16
Sigh. Bosco I kinda recognized, but I had to look up Postum.
Never consumed either as a kid or adult. In fact, my shipmates in the Navy thought I was a total heretic because I never, ever drank coffee of any sort--still don't. I'm a tea drinker, "Tea, Earl Grey, Hot," or if the replicator is down (as usual), plain old Lipton, two bags in a stainless steel insulated cup, pretty much all day long with no cream or sugar needed ever.
As a kid, my breakfast drink/meal of choice was a glass of chocolate flavored Carnation Instant Breakfast. Was just good enough nutrition to keep my dear dad from violently insisting I had to have a bowl of cereal (wet, shredded over-sweetened newspaper), Oatmeal (Oh lord, the horrid lumps and total lack of any real flavor) or some other awful cooked starchy, flavorless cereal product as part of breakfast.
Since my dear mother would not actually ever cook a real breakfast, that was the rotten situation I faced every morning.
To this day, I figure breakfast is an important meal, but only if consumed at the reasonable hour of 0800-0900, once I have recovered sufficiently from my current workplace morning commute of some 71.5 miles one way. Can you tell I'm NOT a morning person?
Old 01-31-2019, 10:24 PM   #17
Airstream - Other
Airstream - Other
Lady Lake , Florida
Thats what i was relating to just wire it to a female connector.
What are I missing?
Old 02-07-2019, 08:53 AM   #18
Hotfoot
2002 25' Safari
Santa Ana , California
7 way to zamp
The simple way would be adapt the Zamp cable with Male spade connectors to plug into connector individually. You'd have to meter out the 12vdc positive and negative. Also may want to fuse for protection.
hotfoot88 is offline   Reply With Quote
Old 02-07-2019, 08:56 AM   #19
Hotfoot
2002 25' Safari
7 way to zamp
appropriate would be to make a fused pigtail mating to Zamp plug that is accessible to the outside.
BatteryMinder connected to Zamp outlet madmac157 Batteries, Univolts, Converters & Inverters 7 12-23-2018 08:16 AM
Charge AS via ZAMP port by Tow Vehicle? airstreaker Electrical - Systems, Generators, Batteries & Solar 9 07-24-2016 11:45 AM
Car-Trailer 7way connector 70 Int.27' capt ken Electrical - Systems, Generators, Batteries & Solar 4 10-26-2013 10:50 PM
HItch ball height via AS and via Leveling mefly2 Hitches, Couplers & Balls 5 03-13-2012 01:56 PM
7way fuse?? steven2themax Brakes & Brake Controllers 7 10-09-2010 06:49 PM
