01-18-2021, 09:59 AM
#21
2019 27' Tommy Bahama
Foothill Ranch
I'm confused.
I'm assuming reference to the "pancakes" are to the LP manifolds/regulators. Aren't these the same ones that are located at the "A" frame where our hitch is?
My understanding is that you just "straight piped" the hose (since it was already "set up" with the AS manifold) straight to the generator - No??? If not, what purpose is the "Pancake" serving that's not already met?
01-18-2021, 10:24 AM
#22
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by hovr
Having that pancake thing inside is really nice. one of the thing I want to figure out is how to avoid mounting it on generator - I don't have a truck so the generator will go in the SUV, with that thing mounted it not only limit where I can put it in the car, it also easy to get damaged when things bumping into each other.
Thank you, I am really learning a lot in this thread!
Take it off...
The 2000i in the AP, the LP stuff in the bag.
01-18-2021, 12:42 PM
#23
2007 22' International CCD
Corona
Your propane generator setup
The pancake thing is the low pressure regulator that feeds propane on demand to the generator engine. This is the one from a Champion dual fuel. It’s absolutely necessary to run correctly. It is fed from the airstream propane regulator at 11” water column, about 1/2 pound per square inch. This regulator is even more sensitive snd reacts to engine vacuum to get the air/propane mixture just right so the engine runs right. The black hose going off to the left goes to the generator input port. The quick connect on the lower right goes to an extension hose from the airstream regulator.
01-18-2021, 01:18 PM
#24
2012 25' FB International
Trent Woods
, North Carolina
The beauty of the Genconnex unit is that the regulator is in the case, not external, a sweet design if you want propane only. You can buy a separate external regulator for use directly off of a propane tank instead off the low pressure gas system on the trailer.
Larry
01-18-2021, 07:31 PM
#25
2021 16' Caravel
Kirkland
Mark, by pancake I meant this:
https://centuryfuelproducts.com/c-03...izer-regulator
I liked Hitch Mountain's kit until I found these thing need to be very close to carburetor, so unless I plan to take the tank off A frame everytime I use the generator, I'd have to mount this pancake on generator after all.
Originally Posted by Mark of SJC
I'm confused.
01-18-2021, 07:34 PM
#26
2021 16' Caravel
Kirkland
Yes, that looks really neat and convenient, still trying to figure out if keep gasoline option is necessary at all.
Larry
01-22-2021, 07:20 AM
#27
Graham
, North Carolina
Propane Generator Setup
2014 16’ Sport
Honda EU2000 gen, Hutch Mountain propane conv.
I use the female LP port on the trailer. Mine is 1/4”. The “pancake” thing is a demand regulator (DR) needed between the low pressure regulated gas and generator. The LP port on the trailer is regulated. I have 2 1/4” 10’ quick connect hoses I use as required. The male quick disconnect on the Hutch supplied DR is 3/8”, which requires a 3/8 to 1/4 adapter I built from parts from Amazon. I mounted the DR on a piece of 2x8. By the way, Hutch instructions recommend not modifying the length of the hose from the DR to the gen. My LP gas company told me 3/8” fittings are the smallest they use and 1/4” fittings are for specialty applications.
I calibrated the setup at my home, 500’ altitude, I camp at 2000’, the propane Honda runs the AC, tv, and led lights simultaneously at 88 deg ambient with no issues. I’m quite happy with it and like the option of gas powered use, although I wouldn’t be surprised if I never used it.
The black hose in the picture of the DR goes to the 3/8” male on the gen, the male brass fitting goes to the adapter, then to the hose, then to the trailer port. The other picture is the adapter broken down for clarity.
01-22-2021, 04:50 PM
#28
Graham
, North Carolina
Intended to include in the above I have a Micro-Air EasyStart installed
01-23-2021, 11:59 AM
#29
Sag Harbor
, New York
Originally Posted by LDDuffy
. . . The “pancake” thing is a demand regulator (DR) needed between the low pressure regulated gas and generator.
. . . By the way, Hutch instructions recommend not modifying the length of the hose from the DR to the gen.
Thanks for that detail, which was my guess about a general guideline. On our Yamaha 1000, the DR is mounted right on the gen/inverter . . . a bit exposed and awkward in terms of stowing in the van, but easy enough IMO.
01-23-2021, 12:26 PM
#30
2004 30' Classic Slideout
Fenton
, Missouri
Here's the regulator on my tri-fueled Yamaha. I use the hi-pressure side of the propane to power it. What's unique about this setup from https://www.uscarburetion.com is the fact that it came with an rpm display and a small adjustment on the regulator that fine tunes the propane or natural gas flow for optimum performance from the generator. Once you start the engine you make the adjustment based on best rpm. That way it can accommodate the differences between propane and natural gas to get the best air/fuel mixture. I've only used it once on gasoline (when it was new for break in).
I've only run it on propane but I do have a natural gas hose that can snap on the line I use at home for my natural gas BBQ. Gives me a lot of comfort knowing I had 3 fuels that I can run on, plus I feel a lot safer not having to carry the gasoline when traveling.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
01-23-2021, 01:03 PM
#31
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Sold the Champion Dual Fuel; bought the Honda 2200 Genconnex
The Champion Dual Fuel 3400 worked fine for us for 3 years on propane. It can run the 15000AC without the Easystart no problem. But, for me, 95lbs was becoming a pain to load/unload when I turned 70 this past year, so I sold it and bought the new Honda 2200 Genconnex unit. Sweet design and 3 year warranty. Several friends have this unit, modified by Genconnex. No external carb/manifold to worry about mounting somewhere, like is required with the Champion 3400 Dual Fuel or like the "Hutch Mountain conversion" on the Honda. Before I purchased the Genconnex last month, I had already tried a friends Honda 2200 Genconnex converted generator last summer and it fired up my AC 13000 or 15000AC. I cycled it on and off to test for about 3 min each; no issues.
The propane conversion from Genconnex is integrated into the Honda chassis/skins with just a quick disconnect port on top. Tell them you have an Airstream, they send you the right hose with quick disconnect for your AS propane QD port in front, and also works with separate 20lb portable propane tank we use for our bbq and fire pit. All is well...drives either one of my AC units, microwave when needed, and everything else! Genconnex also included a high altitude jet for when I am in Wy in the summer. 45lbs, uses propane, runs my AC and other appliances in the AS...I am happy camper!
01-23-2021, 01:04 PM
#32
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
X2
An often overlooked feature having an adjustment block on the manifold, and tach/hour meter for easy altitude adjustment.👍
BTW...
01-23-2021, 01:18 PM
#33
, Texas & Wyoming
Originally Posted by ROBERT CROSS
X2
BTW...
yes, I will have to use the included Allen Wrench to swap out the high altitude fitting, but no big deal. Also, the Bluetooth feature for your phone, gives you the tach, plus keeps track of hours, oil life, and can remote stop are some benefits....but no bulky carb...I had to deal with that on my Champion, so nice not to worry about storing it, keeping the QD fittings protected etc...minor nits for sure, but still nice to have a clean neat package like Genconnex has done, IMHO.
01-24-2021, 10:29 AM
#34
2014 25' FB Eddie Bauer
Vero Beach
You folks MUST stop this! For this summer’s trip around the perimeter of the US to finish the lower 48 we are already doing lithium batteries, a bigger mattress, new recliners, a potable washing machine and who knows what else.
Now I need a pair of Bluetooth enabled generators with RPM meters to replace my perfectly good Hondas?
I think it’s time I cancel AirForums!
Silver Cliche’
Follow us at...
silvercliche.blogspot.com
