03-24-2018, 01:17 PM
Journeyman
2016 25' International
Amherst
, Massachusetts
Which Brackets for Renogy Rigid 100w panels?
Gang,
I'm planning a DIY solar install in April and I'm wondering about brackets. Clearly the AM solar brackets are best, but they are SO costly I just can't do it.
In terms of Renogy brackets, they have the standard Z bracket and then the curved bracket. I had imagined I would just use the curved brackets on the outboard side of each panel, but then I realized that the curved brackets make it easier to remove the panel once I've stuck the mounts to the roof (whereas the Z brackets are very difficult to detach from the panel).
I'm wondering if my assessment here is correct? Essentially if I use Renogy Curved brackets on all four corners of each panel I should be able to remove the panels if I really need to?
(At about $30 per set, the Renogy curved brackets are still MUCH cheaper than the AM solar version.)
Thanks!
03-24-2018, 02:26 PM
2016 27' Flying Cloud
Hartsburg
, Missouri
Or make your own, See my thread on my solar install under "Frank's solar upgrade", will try and include link below.
http://www.airforums.com/forums/f448...-a-164507.html
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
03-24-2018, 03:11 PM
2013 25' International
Boise
, Idaho
Renogy Curved-Z Brackets
I recently installed 4 panels on my 25'. I used the Renogy Curved-Z mounts that I purchased quite economically (around $20 per). After I installed them, I realized I couldn't stand the way they looked. Another person might have looked at them and said, "good enough" - but every time I noticed them, I felt a little pang of disappointment. And after spending a lot of money on this project, I didn't want to feel that way.
So, I changed them. I bought the AM Solar mounts and spent way too long swapping them out. And it was worth every cent and every hour of work. YMMV and the Renogy mounts may work for you, but do noticed they won't let you get the panels less than 2.5 from the bracket base.
-Adam
03-24-2018, 03:27 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Home made brackets
I made these for my renogy 100watt x panels. Made from 1 1/2 aluminum angle. Stuck to Airstream with VHB tape and alpha one over the top. I have less than $20 in all 8 of them.
2022 25' Flying Cloud
NCR
, Ontario
this is what i have. also make your own tilt bars out the bar stock and easy to get wing nuts
03-25-2018, 09:48 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Using the proper supports designed for the panels is more likely to result in a trouble free installation years down the road.
03-25-2018, 09:57 AM
2015 30' Classic
Pleasanton
The standard Renology Z bracket works well, provides sufficient surface area to use VHB tape and panels can be removed if need be after the brackets are mounted.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
03-25-2018, 10:01 AM
2018 25' Flying Cloud
Portland
, Oregon
-Adam
Wow, that was quite a project. Not wanting to repeat your experience, as fun as it sounds, I’ll just start with AM Solar! Do you use the standard height AMSolar brackets or did you have some tall ones mixed in to accommodate the Airstream’s curve?
