07-05-2012, 07:41 PM
2012 25' FB Flying Cloud
Georgetown
Where to carry gas for the generators?
Hi,
We have two Honda EU2000i (one is a Companion). I would like to carry about 2 gallons of gas in addition to what is in the generators. The question is where is the best place to carry it? I would rather not put it in the truck bed under the tonneau cover since, in my experience, the gas can gives off much more gas odor than the generators (with the vents closed).
Gas is about 6.2 pounds per gallon, so 2.5 gallons would be 15.5 pounds, or two 1.25 gallon cans would be 7.75 pounds each.
Would it be OK to put either 15.5 pounds or two 7.75 pounds on the rear bumper of the Airstream?
Or would it be OK to put it on the hitch on top of the batteries?
It seems that it might be better to spread the weight by using two 1.25 gallon cans at 7.75 pounds each instead of one 2.5 gallon can at 15.5 pounds.
Any thoughts?
Thanks in advance,
Jeff
07-05-2012, 07:52 PM
2014 Bowlus Road Chief
Cumming
, Iowa
Convert to propane?
John S.
07-05-2012, 07:56 PM
Eharv
2007 25' Safari SS SE
Austin
I also would suggest to convert them to propane----much more safe than gasoline.
EHARV
WBCCI Life VAC CAC THLU # 6610
AIR FORUMS # 16697
TAC # NM-4
GOOD SAM CLUB Life # 4704
07-05-2012, 08:19 PM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
I tow with a 2.5G can on the battery box secured with a bungee. Works fine. But then I try not to camp where I need AC and if I do, its with 30amp hook-up.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
07-05-2012, 08:20 PM
2010 27' FB Classic
N/A
If you decide to continue with a gas generator, this is what I use for gasoline fuel storage. No leaks, no fumes, IMO just the best containers for gasoline or diesel. I just saw R carl spoke up first. I guess I type too slow!
Fuel Cans : Gas Pack : Gasoline Containers : RotopaX.com
07-05-2012, 08:22 PM
2006 19' Safari SE
Tucson
We have a freind who carries her generator gas on the tongue behind the propane tanks...she rests it on a carpet sample square to cushion it and lashed it in good with bungee cords...make sure they are very secure, though...
We carry our generator gas in the bed of the truck, whcih has a tonneau cover. If the containers are tightly closed they don't put off too much odor...but they must be tightly closed.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
07-05-2012, 08:25 PM
2006 19' Safari SE
Tucson
Well those are pretty cool... I may have to look into them. I like that they are easy to pack.
AirForums #21900
PastPrez, 4CU/WBCCI
07-05-2012, 08:28 PM
Salem
, Oregon
Originally Posted by barrettjl
Hi,
Any thoughts?
Thanks in advance,
Jeff
Hi, for my Alaska trip, my gas can was above my battery box.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
07-05-2012, 08:43 PM
2010 27' FB Classic
N/A
They go on sale every so often.
07-06-2012, 05:58 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
We have converted to dual use, LPG.
Still use gasoline on a regular basis just to keep both systems working properly.
Pancake 5gal lpg tank stored in AS "trunk", 1 1/2 gal gas container in "tool storage" box.
"You don't know where you've been until you leave, enjoy life" RLC
07-06-2012, 03:54 PM
2010 27' FB Classic
N/A
Ammo, gasoline and propane. Bob, your ready for anything.
07-06-2012, 04:07 PM
2002 25' Safari
Fountain Inn
, South Carolina
I carry an Eagle metal safety gas tank in the bed of my truck with a topper on the bed. No fume problems. I have been using it for about 5 years without problem. I bought it from Lowes.
EAGLE 5 Gal. Metal Gas Can (Red)
Bud
07-06-2012, 05:46 PM
2014 25' Flying Cloud
Cuddebackville
, New York
That's where I carry my Honda 1000i.
07-06-2012, 09:56 PM
Salem
, Oregon
Hi, here is where I carry my Yamaha 2400.
07-08-2012, 06:52 AM
Georgetown
Thanks for the posts. I got a 2.5 Gallon No-Spill can, and it fits great just behind the propane tanks on the battery compartment.
07-15-2012, 09:39 AM
2008 27' Safari FB SE
Pfafftown
, North Carolina
Gasoline Container
I just ordered a Rotopax gasoline container and two diesel containers. They are pricey but I found a 15% discount coupon code TACOMA which worked. Fuel Cans : Gas Pack : Gasoline Containers : RotopaX.com
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2022 Ford F350 King Ranch, 6.7 Diesel, 4X4 (Big Red)
WBCCI 3823 - Unit 12 | AIR 48265
07-15-2012, 09:47 AM
2005 28' International CCD
Arlington
, Virginia
I'm posting a blog when it's all finished and set up, but I also have two Honda 2000i's and am putting together a long-run system connecting a single six gallon maritime tank via fuel lines and a "T" splitter to the two generators. Key is a "long run" sealed fuel cap for each generator. Plan is to carry the six gallon tank on my tow vehicle roof in a cargo basket. That way I can just run the fuel line to the generators without having to move it. Worst case, six gallons isn't too heavy, I just lift it off and place it next to the two generators (for example, in the woods twenty feet away for less noise). Six gallons should run the two Hondas for about 20 hours, or 3 nights of AC/ battery recharge while boon docking and not having to wake up and refill them. ;-)
Airstream Dad
08-07-2012, 08:18 PM
Saco
, Maine
Airstream Dad
Do you have any photos of this yet? Would love to see them... I just ordered a BERG dual line 6 gallon maritime extended fuel tank for my two 2000i Yamahas... also wondering where to keep them... I can fit both Yamahas on my hitch, but no room for a gas can there... wondering if I should put one of the Yamaha generators in the RV trailer, and put the gas can on the hitch along with the other generator, for travel...
